20 Most Recent
Panasonic KXTG4011 Cordless Phone Questions & Answers
Says No Link...Reconnect base AC Adapter
Disconnect the AC adapter from the unit, wait for 5 seconds, then reconnect. The plug may have become loose over time or not be fully inserted. If that does not work, try re- registering the handset.
To re-register, see screenshots attached.
5/20/2021 4:35:20 AM •
Panasonic...
Answered
on May 20, 2021
Additional handset installation
We're glad to read you were able to register the handset. Please use the below link should you have any other issues registering a handset.
http://service.us.panasonic.com/OPERMANPDF/KXTG4011-MUL.PDF#page=23
5/28/2014 7:23:33 PM •
Panasonic...
Answered
on May 28, 2014
Base charge uniden
Hi sir.
handset
follow this:
press MENU
"Initial setting"
OK
"Registration"
OK
"HS registration"
OK
on Base unit:
Press and hold
{LOCATOR} for
about 5 seconds.
11/14/2013 6:23:54 PM •
Panasonic...
Answered
on Nov 14, 2013
I cannot make calls
Change the setting according to your telephone service line.By default it is Tone. Change it either as Pulse or rotary .Select the desired settings and try it.
7/25/2012 7:57:05 AM •
Panasonic...
Answered
on Jul 25, 2012
Now it is saying check tel line
There's some problem with the phone's ability to detect a dial tone. Check that the phone's base is connected to your home's AC power and the telephone cord is securely connected at the phone base and wall jack. If still not working, continue checking by disconnecting the cord from the base and connecting a different working phone. If the phone does not work while connected to this cord - there's a problem with the cord. Try replacing the cord between the jack and phone. If it still won't work - you may need to contact your telephone company's repair service to get it fixed. Good luck!
5/27/2012 12:02:19 PM •
Panasonic...
Answered
on May 27, 2012
Unable to set answering system
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at
WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.See page 27 of the manual for detailed instructions on HOW TO OPERATE THE ANSWERING SYSTEM FEATURE.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
11/10/2011 12:50:48 AM •
Panasonic...
Answered
on Nov 10, 2011
Can you speed dial on
This model doesn't have a speed-dial or one-touch dialing feature. It does have a phonebook feature that allows you to store up to 50 phone numbers, and you can select an entry and the phone will dial automatically. Not quite the same, but it's all that's offered.
The manual gives the steps for entering names and numbers into the phonebook, and for selecting and dialing an entry.
9/13/2011 12:55:44 AM •
Panasonic...
Answered
on Sep 13, 2011
