I have bose acoustimass 15. I connect to receiver pioneer VSX-917 V-K, and i tested all lines with speakers set up and all 5 cubes speakers are work, except the bass. I turned off the power on unit all 5 speakers still working except the bass. Line subwoofer out on receiver is work.
what is the problem with the bass ? how to fix it ?
You are only given one answer from our Expert Ray with the brief answer 'No sorry'.
This is your VSX
REAR TERMINALS
HDMI 4 in
HDMI 1 out
AV (Composite) 2 in
Audio 1 in (assignable)
Digital Coaxial 1 in (assignable)
Digital Optical 1 in (assignable)
Monitor Composite 1 out
Preout 0.1ch (SW)
Speaker 5 ch out (FRONT, CENTER,
SURROUND)
and this is your Bose. Find the manuals for both and read them. connecting them
A: Glancing at the specifications of the Bose Acoustimass 10, the system is stated to be compatible with A/V receivers and amplifiers rated from 10-200 watts per channel, and from 4 ohms to 8 ohms. Aug 17, 2014
The Bose speakers with the cubes and bass module are all interconnected with a proprietary cable available from Bose, if lost you get a replacement by called 1-800-444-BOSE.
When you connect the speakers all wires run from the receiver to the base module first, then out to each of the speakers. All terminals on the bass module are labeled.
The Bose cubes are all identical and can be used in the front or back positions.
Try to keep them at ear level or aimed at the listening position for best sound.
Either your ambient noise level is too high for the test, or you need to increase the volume for the test tones.
For any such audio calibration testing your ambient noise level should be as quiet as possible, preferably below the measurable level of an SPL meter...usually 50dB for most models.
Clarify, did it ever work for you? Were both receivers used properly configured for the subwoofer? Did you also test the other speaker moduels running off the subwooferto see if they work?
Speaker Receiver setting
• Left and right LARGE
• Center LARGE
• Left and right surround LARGE
• Center surround* LARGE
• LFE/Subwoofer ON
With an Acoustimass 16 Series II system or upgraded Acoustimass 15 Series IlI system only.
yes of corz,, u can use any of that but dont go pass the power of your power amp,, becoz,, it coss damage 2 your speakers,, and thats expensive... ps. . dont revers the polarity
