20 Most Recent Pioneer VSX-818V-K Receiver Questions & Answers
The formats that Xbox 360 supports include: MP4, M4V, MP4V, and MOV. So all you need to do is find a proper Blu-ray ripper that can help you convert Blu-ray to MP4 or other supported formats.
Here's one that's been getting positive reviews from users: Leawo Blu-ray Ripper.
It supports a lot of different formats, including the 4 formats that the Xbox 360 supports.
Here's how: Does Xbox 360 Play Blu-ray
Pioneer... | Answered on Jan 08, 2020
Press TUNE+ & AUTO SURR/DIRECT keys continuously for 2 sec. and it will tell you the fault it encountered if the receiver is in otherwise working condition.
Pioneer... | Answered on Sep 14, 2019
You are doing nothing wrong at all. It's just that as you say it has no phono input. Which means the sockets you have will NOT amplify the signal. So you need to buy a magnetic cartridge pre-amp and once connected to the aux the weak signal will be at the normal level.
Pioneer... | Answered on Jul 12, 2017
I imagine you can't see the set up menu to assign the proper type of video input (analog , composite , HDMI ) . On the 818 and previous series the set up menu will only appear through a Component (RCA green , blue and red ) or Composite (RCA yellow) BUT NOT THROUGH HDMI CONNECTION! That's why it will be necessary to run on of those two cable , match the input on the TV , on the Pioneer remote press Receiver then setup and the Menu should appear.
Hope i could help.
Pioneer... | Answered on Jan 23, 2014
wondering if input levels are too high on some channels causing safety limits to shut it out..check level outputs on eguipment.
Pioneer... | Answered on Jan 08, 2014
you would need a Tester with Ohm or continuity measurement function you would still need to pull the fuse out But like i said if you need to go and buy one of those and may be never use it again it's easier to take the fuse to an electronic store and get a new one .
Pioneer... | Answered on Dec 20, 2013
Is no reset button on those receiver , if nothing is wrong with the outlet and the receiver cord , the next possibility is the fuse who is inside the receiver near where the power cord enter the receiver . you should see a small glass or ceramic fuse ( tube with metal on both end ) if you don't have anything to test it just take it to "Radio Shack" or other electronic store to get a new one ( less the $ 3 ) replace and give it a try . Please don't forget to respect all safety cautions to work with electricity.
Make sure your front speakers are set to small in the setup menu. Regardless of how large your speakers are, if they are set to large the receiver will put the low frequency sound out the speaker jacks and turn off the subwoofer output
Pioneer... | Answered on Dec 26, 2012
have you look to see if the fuse has blown that usually the problem, just take the cover off and we'll see the ormore then one fuse check them all.
Pioneer... | Answered on Jun 24, 2012
If there is no power on on the primary side of the transformer look for a open fuse.
Pioneer... | Answered on Apr 05, 2012
Pioneer VSX-818V-K Receiver Logo
79 questions posted
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
ThaMp3Doctor
ThaMp3Doctor
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Audio Players & Recorders
Most Popular Question
no sound from subwoofer
  • Audio Players & Recorders
