The 200.16 jam indicates that the input sensor was covered when the printer was powered on or reset, or a cover was opened/closed. You may also check the following: 1. The paper being used is within specification and has been loaded correctly. 2. Any previous jams have been completely removed. 3. The printing environment is within acceptable temperature and humidity ranges. 4. If the tray was overfilled or a paper jam occurred, sheets of paper may have come off the media stack. 5. If you don
5. If you don't see or remove the separated sheets, they may remain ramped up the paper dam or at rest in the paper path. Often, these sheets will cover the input sensor or lead to a double feed.
For further assistance, please call Lexmark Technical Support.
You may also click on the linkhttp://bit.ly/o8lfoY, this will give you instructions on how to go about the procedure.
The printer will stop printing is there is an error, check for any paper jam before printing. Take note of the error message and locate the exact jam.
Use the manual feeder when printing on envelopes. You may click on the link http://bit.ly/rnHp5b to see instructions on how to go about the procedure using the manual feeder.
