Lexmark E342n Laser Printer Logo
Posted on Jun 05, 2008
PAPER JAM ERROR MESSAGE
LEXMARK E342N HAS 200 PAPER JAM REMOVE CARTRIDGE MESSAGE. THERE IS ABSOLUTELY NO PAPER JAMMED IN THE PRINTER. HOW DO I FIX THIS?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 22, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1541
Points
11
Your sensor flag in the back is broken or missing
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jan 20, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
5394
Points
6
Sale error el codigo c2557
Del Walton
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Jul 23, 2012
Del Walton
Contributor
Level 1:
New Friend:
Answers
8
Questions
0
Helped
5791
Points
19
Here is what probably is your problem.... The input sensor number 1 is bad.... It's the sensor directly under the toner and photo conductor.... replace this sensor. [email protected]
1 Related Answer
Anonymous
  • 310 Answers
  • Posted on Jun 05, 2008
SOURCE: LEXMARK E342N
can u explain mean clearly....... restart the machine and then try it........
1helpful
I keep getting an error message about a paper jam for my printer but there is absolutely no paper jammed anywhere in the machine.
Have you tried a new toner cartridge, The toner cartridge has moving parts, and of the cartridge gets stuck, the printer may indicate a paper jam.
Also paper often tears when clearing jams, and the little shreds of paper can stay in the rollers of the printer and keep it jammed. Make sure to inspect all the rollers to make sure they move freely, and do not have anything stuck in them.
2answers
Trying to print but keep on getting error 200 message when i press select the printer switches off.
Hi what is your make and model please then i can look up the error code for you as this changes for each make and model thanks
200.12 paper jam
The 200 and 200.xx Paper Jam error messages indicate a problem with paper jammed at the front of the printer, under the toner cartridge. To resolve this issue, please refer to this article: http://bit.ly/122frro.
My printer lexmark e342n 201 jam error code, what the are problem, fuser or pick-up roller and how to soft that problem. tq
If you are getting 201 error code, it means a paper jam has occurred. To fix this problem please Open the front door. Remove the toner cartridge and remove the jammed print media.
Click on the link http://bit.ly/p1jJcd to see instructions on how to go about the procedure.
For further assistance, please contact Lexmark Technical Support.
Lexmark E342n. The paper jams after it prints and before ejecting. Paper is not wringled when pulled out. I open the back door and the end is there. It is like it is using shorter paper then letter.
Power off the printer, check the entire paper path of the printer for any jammed sheets of paper or other obstructions. Remove any obstructions you find and try printing again. Check if the page setting may be incorrect or paper size and the paper size settings do not match and make sure that the paper size in the printer driver settings matches the paper in the tray.
The printer message is 202 paper jam open rear door. There is not a paper jam in the printer.
These are the messages got stuck in print queue, you have to release the print queue, First got to Printer and Faxes, there would be your printer icon (Lexmark E342n) Laser printer icon, double click on that, you would see all the messages stuck in queue, release or delete from there. that has to work, please let me know if it works or not
2answers
Lexmark E 342 n paper jam with error code 201
According to the LexMark support page, this is most often related to not getting the print cartridge assembly properly positioned. (Left and right sides not fully in place). Another possible source is paper in the output tray when using the double sided printing feature. (This leads to grabbing an extra sheet when it tries to retrieve the paper to print the second side. Paper stock thickness will change the number of pages printed before this happens.).
I hope this helps.
Code 200 Paper Jam Error
Hi Mike,
This error can be caused by many reasons, some of them are:
Caused by Paper Stuck Under the Second Transfer Roll
Sporadic or Intermittent 200 Paper Jams
"200 Paper Jam" Resulting from a Possibly Damaged Tray
"200 paper jam" When Attempting to Print from Tray 2
To troubleshoot this problem, please click the links with their respective causes.
Please rate it fixya if it was helpful.
Thank you
2helpful
4answers
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
