If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
you need to setup the wireless connection if you havent already and your router needs to be a "wireless" router in order to create that type of internet connection. Have you laptop then scan for one which would be the one you just made and input the correct information to connect. If that doesn't work I'd suggest getting a new wireless router
Once its connected you will have the blue light in the belkin router
1.Turn on the wireless switch in your laptop
2.Click on start menu--->control panel--->Network and internet--->Network and sharing
3. In the right hand side click on "Change adapter settings or Manage network connections"
4.You will see the wireless network connection
5.Right click on wireless network connection and click on Connect/Disconnect
6.you will be able to see the network name,try to connect it.
7.it will be connecting and then connected
8.try to able to go online in the laptop
I managed to figure it out. I had to clone the MAC address to get the router to connect to the Internet.
I still have another problem though, my laptop still won't connect to the router. I'm using Vista, is this a possible network adapter issue? My laptop is fine at connecting to other wireless networks round my friend's houses/libraries...
Hi the router has not picked up your IP address.follow this Turn off your wireless router and internet connection and your laptop aswell for 30secs .Then first turn on your internet (if seperate from the router) if not switch on the wireless router/internet hub and wait untill the lights stop flashing then switch on your laptop and that should work.
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
If your Desktop computer is hardwired to the router and your laptop computers can't connect wirelessly, it could be your wireless computers are not synchronized with your router by not having the same settings as the router.
You can use the desktop machine to access your router web interface (setup page) to check the wireless settings such as SSID (Network Name-> Name of your wireless signal shown on your laptop computers), channel and security (wether it is WEP or WPA encryption)
The channel and network name will be automatically detected by the wireless computers. If you have an encryption/security on the router, you need to type the password on the wireless computers for them to authenticate.
Make sure you have the wireless icon on the taskbar lower right side. If it does not show connected, click the icon and search for wireless devices, you should see the router. connect to the router. Also make sure you have a solid DSL/CABLE status light on the service modem. BPCS
