20 Most Recent Belkin (F5D7231-4) Wireless Router Questions & Answers
Have you tried restarting and resetting the router as well ?
Belkin... | Answered on Jul 09, 2019
It can be that your iphone doesnt work with 2.5ghz but maybe 5Ghz. Try setting up your router with 5Ghz and see if that will help
Belkin... | Answered on Jan 01, 2019
This depends on if your computer is hard wired or wireless. If it is hard wired you sometimes have to reset the router, pull the plug wait 30 seconds then plug it back in also do this for the computer that is not connecting, this will start the hand shaking process over. If it is wireless you may have to reset the wireless adapter. the easy way to do that is to hover the mouse icon over the wifi icon on the bottom right of your screen now right click on that and select troubleshoot problems, this will reset it. If this fails then on your start on the bottom left normally open that and in the run box type cmd now hover your mouse over the cmd and right click and select run as administrator a black box will open in there type netsh winsock reset and hit enter after doing that you will have to reboot your machine, hope you get back online..
Belkin... | Answered on Sep 29, 2018
There are two possible solutions, depending on which password you can't remember. If you remember the password to log into the router, you can go to the wireless security page and see the wireless password (you may have to uncheck the "obscure password" box to see it). If the password you can't remember is the one needed to log into the router, I believe your only recourse is to hold the reset button for at least 10 seconds to restore the factory defaults. NOTE: you will then have to re-configure the router as if you had just taken it out of the box.
Belkin... | Answered on Sep 18, 2018
Integrated Router/Firewall/VPN -40 to 85C, Immunity to EMI
Belkin... | Answered on Aug 28, 2018
Step 1 : Check the IP Addressof the Xbox And take a note of it
Step 2 : Open RSP By typing 192.168.2.1 on the Address bar of the internet explorer
Step 3 : On the left side Click Firewall
Step 4 : Leave the Password blank and click Submit
Step 5 : Disable it And Apply Changes
Step 6 : On the left side Under Firewall Click DMZ
Step 7 : Add the IP Address of the XboX in DMZ
Step 8 : Click Apply Changes
Step 9 : Restart the Router
Step 10 : Test the Connection
Belkin... | Answered on Aug 18, 2018
Steps to find a WEP key:
1. Open a browser (the program used to access the internet).
2. Type the following into the address bar of the browser. If using a Belkin router type "192.168.2.1". The address bar is the area where webpages are typed. It is important when typing in that there is NO www. before the numbers, but do put http://
3. If all has gone well this should open a page that says Belkin.
3. There may be the need to login. When using a Linksys if you don't know what the username and password are it may still be the factory settings, and so enter in "admin" for the username and "password" for the password. If using a Belkin router, the factory settings often come with no password, so just click submit without typing in a password.
4. Click on a) "Wireless" or b) "settings".
5. Click on a) "Wireless security" or b) "wireless settings".
6. There should be a page with a WEP key listed.
7. Write it down/copy and use as you wish!
Belkin... | Answered on Mar 21, 2018
Verify which MAC Address U have Cloned. MAC Address of Your PC WiFi and Cloned One must not be same otherwise it will not work...
Belkin... | Answered on Dec 04, 2017
From http://www.belkin.com/support/, type the Belkin part number “F5D7231-4” in the “Search” field. Click “Search”
From the results page, click “F5D7231-4”.
Scroll down to the Software & Updates section. Click on "F5D7231-4 Firmware Update".
Locate the firmware that corresponds to you routers version number. To download the new version of firmware, click the download logo.
A window will open that allows you to select the location where you want to save the firmware file. Select a location. You can name the file anything you want, or use the default name. Be sure to save the file in a place where you can locate it later.
Note: We suggest saving this to your desktop to make it easy to locate the file. When you have selected the location, click “Save”.
The download of the firmware is complete. To update the firmware,
follow the next steps in “Updating the Router’s Firmware”.
Make sure that you have the router Wired to your computer before you continue with the firmware update instructions.
Belkin... | Answered on Apr 20, 2017
Reset Belkin WEP key or WPA pass phrase
Belkin... | Answered on Jun 29, 2016
You will have to connect an ethernet cable from the router to your computer. Enter http://192.168.2.1 in your browser to log into the router. Your passphrase will be listed under "wireless settings" or similar.
If you can't log into the router, you'll have to do a hard reset. Look for a very small button on the back or side of the router and, while it is powered up push the reset button in for 10 seconds or so untill the lights on the front flash on and off. You can then get into the router using the above method. The default password is left blank. You will then need to go through setup and create your own pass phrase.
If you need further assistance post back to this thread.
Belkin... | Answered on Feb 04, 2016
Hello:
The Belkin F5D7231-4 has no password by default. If you changed the password and can't remember it, you can reset the router to default settings by pressing and holding the recessed reset button on the back of the router for at least ten seconds.
Manual: http://cache-www.belkin.com/support/dl/f5d7231-4.pdf
Belkin... | Answered on May 03, 2014
Belkin (F5D7231-4) Wireless Router Logo
469 questions posted
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Jeffrey Groves
Jeffrey Groves
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Belkin Computers & Internet
Most Popular Question
reset
  • Computers & Internet
