Take your time with this step! The steel band is part of the brake for the saw. You will need to take very special care and take your time when putting it back together.
The trick is in the braking lever. you will need to pull back on the braking lever, align the steel band over the steel drum, and and align the two contact points that will connect the steel band to the braking lever. After it is in place actuate the lever to see if it is working correctly. This function should cause the chain to stop moving and move when the brake is released. Where strong rawhide gloves to protect yourself from the chain. Good-luck.
