20 Most Recent Poulan Pro Chain Saw 46cc 20" Questions & Answers
I have a Poulan 2055 2.0 C.I. CHAIN SAW. NOT A CAR. I have changed the coil on it. When I try to crank it, it turns but nothing else.
CHECK SPARK FIRST, THE CLASSIC WAY FOR 100 YEARS GOOGLE HOW. 5MILLION HITS. i USE NEW TEST SPARK PLUG TO TEST SPARK. GROUND TO ENGINE BLOCK (METAL) IF GOOD , SPARK NEXT IS BAD FUEL OR EVEN THE AIR FILTER PACKED UP IN SAW DUST EASY AS PIE. OR CLOGGED FUEL FILTER FROM BAD FUEL AND LAST CLOGGED CARB FROM BAD FUEL OR AMAZING AS IT IS ALL 3 WRONG, FUEL DOWN. I ASSUMED COMPRESSION IS GOOD. HAND PULLED STATER . OR NOT USING CHOKE OR TOO MUCH.
4/13/2023 2:51:09 PM • Poulan Pro Chain... • Answered on Apr 13, 2023
How far do i turn the high low idle srews out
I always start at 1 1/2 turns out and then with the saw running adjust as needed 1/4 turn at a time
1/19/2023 9:41:31 PM • Poulan Pro Chain... • Answered on Jan 19, 2023
2answers
I have a problem setting the High and low carb
try starting with both needles turned out one and a half turns, than fine tune from there. Make sure you are on the rich side of both when finished.
1/14/2022 7:37:06 AM • Poulan Pro Chain... • Answered on Jan 14, 2022
Poulan PP4218 avx; tube (line) inside gas tank
cheapest way is a new fuel tank from e-bay that has it all installed you can remove the rubber grommet around the lines to get it out then get a new filter to push on the line BUT will it be cost effective against what can be obtained from e-bay
9/25/2021 2:23:09 AM • Poulan Pro Chain... • Answered on Sep 25, 2021
7answers
Poulan pro with tooless chain tightening - chain will not stay on
i have a 4620 poulan that had the same problem. use it for 10 minutes, spend 15 minutes reinstalling the chain. i sent poulan an email threatening to sue them and they decided to send me the parts to change it over to the old style for free. try poulan.com
5/13/2021 9:57:17 PM • Poulan Pro Chain... • Answered on May 13, 2021
How do I Adjust jets on poulan pro 295 chainsaw?
Find the air/fuel mixture screw to adjust. Clock wise to lean Counter clock wise to richen
3/1/2019 12:03:38 AM • Poulan Pro Chain... • Answered on Mar 01, 2019
2answers
I have two poulan chain saw with the same problem can not get the gas to flow from the tank to the carb .the primer fine also the fuel lines have been replaced
It is important if you have changed the fuel lines that they are reconnected correctly, the bubble is a purge not a primer, so it pulls fuel from the carb and dumps back to the tank, on the back of the bubble there are two connections, one long one short, the long connection is the pressure side so goes back to the tank, the short one is the suction side so this goes to the carb connection nearest to the metering cover ( the one held with four screws) the fuel hose from the tank with the filter on the end goes to the connection on the carb nearest to the pump cover (held with a single centre screw) if you have not already done so replace the fuel filter in the tank.
2/18/2019 10:06:48 PM • Poulan Pro Chain... • Answered on Feb 18, 2019
Diagram for fuel line routing for a poulan 2150 chainsaw?
The 2150 has a remote primer, so there will be three pipes, the pipe coming from the fuel tank with the fuel filter on the end is the main fuel tube, this fits to the connection on the carb nearest to the pump cover on the carb ( alluminium cover held with a single screw ) the other connection on the carb has a pipe to the shorter of the two connections on the back of the primer ( suction side ) the longer connection on the back of the primer ( pressure side ) has a pipe back to the fuel tank, so the primer pulls fuel from the tank, into the bulb, and dumps it back to the tank, it does not push fuel into the carb, this way you can depress the bulb as many times as you like without flooding the engine.
10/18/2018 4:51:41 PM • Poulan Pro Chain... • Answered on Oct 18, 2018
Fuel line diagram poulan pro ppb 15oe
1/17/2018 9:17:58 PM • Poulan Pro Chain... • Answered on Jan 17, 2018
How to remove muffler from pouland 46cc chain saw
Remove the 2 screws "1" and "2" to remove the muffler. wumrwjbbo8trgaaaabjru5erkjggg==
1/8/2018 10:06:24 PM • Poulan Pro Chain... • Answered on Jan 08, 2018
Poulan woodshark type 1,2,3,4,5 differences
Anytime there is a difference in the "Type" something was changed on the product. To determine all of the changes in all types would take some time going through each of the part's lists.
1/8/2018 10:02:22 PM • Poulan Pro Chain... • Answered on Jan 08, 2018
What Is exact placement of fuel lines?
12/7/2017 7:21:26 PM • Poulan Pro Chain... • Answered on Dec 07, 2017
Chain damage
The chain could be stretching. Are you using a good quality bar and chain lube? Never use old motor oil. Once the chain has jumped several times it may be bent. Properly adjust the chain and keep an eye on it while using. start with a new bar and chain and watch the tension. You can also replace the tool less cover with a standard cover for about $25
11/20/2017 7:48:00 PM • Poulan Pro Chain... • Answered on Nov 20, 2017
ETHANOL fuel has completely dissolved
Yes, anything can be fixed, well almost. I've had the same problem with small engines. Start by taking the plastics off, you should be able to find the rest of the fuel line that goes to the primer bulb. Then from the bulb to the carb. You need to the correct size fuel line and replace it and put on a new filter. Just remember, if it damaged the lines, the carb needs to be removed and soaked or replaced. To keep from going through this again I recommend the pre mix two cycle fuel, just make sure the ratio is correct, chainsaws are usually 50:1 and other small engines run 40:1
8/8/2017 5:26:36 PM • Poulan Pro Chain... • Answered on Aug 08, 2017
2answers
It is new and will not fire up
take it back for a warranty service check is the stop switch been activated
1/2/2016 4:21:36 PM • Poulan Pro Chain... • Answered on Jan 02, 2016
2answers
New saw - will not
It's possible the brake is on. Try pushing the brake forward then pulling it back until you hear it click. Then try cranking it again.
11/24/2015 5:54:11 AM • Poulan Pro Chain... • Answered on Nov 24, 2015
Poulan Pro Chain Saw 46cc 20" Logo
513 questions posted
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
View Most Popular
Poulan Garden
  • Poulan Garden
Most Popular Question
two poulan chain saw same problem not
  • Garden
