Did you carry out the correct bleeding procedure? back wheels off the ground half engine revs, five forward shifts the five reverse shifts, now put unit in bypass and same again, carry this out two or three times until the there is a smooth drive and no noise, if this does not work check the brake disc on the side of the unit is not binding, if this is ok then there is some internal damage, inside the unit there is a alloy centre section with a cylinder block and pistons running on it, if the running face is scarred then oil will leak between the two mating surfaces and there will be little or no power, this will get worse the hotter the unit gets. You can remove the two half's of the unit and replace these components.
SOURCE: craftsman 20.5 hp. auto trans.lawn tractor loss of drive power
Hello:
>>You can View a Breakdown/IPL of
this Engine at this Site Addy,
http://www.outdoordistributors.com/
and Select the H. Then Select Hydro-
Gear. Then Select Don't have Part
Numbers. Then Enter the Model
Numbers 319-0650. Then Select your
Model and Download the File for
Online Viewing.
From your Description it Sounds like the Internal Pump is Worn and is Loosing Pressure as the Unit Heats Up and the Components Expand from the Heat.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: My Husqvarna YTH150 right side axle keeps coming
According to Tecumseh/Peerless, the manufacturer, there are no user serviceable parts available and it should not be disassembled by the end user.
This is one of those factory sealed units that can only be replaced, not repaired. It takes a lot of "special" tools and equipment to work on them
SOURCE: Transaxle not working.
on the back of the mower you will need to remove the back there is a hose comeing out of the trans its a vent tub remove the plug and put some good 30 w oil in the tub tha should fix it
SOURCE: I own a Husqvarna 54"
Depens wheather its a Tuff Torque unit or a Hydro gear unit, the Tuff Torque unit has the bypass lever on the top of the box, it will normally have a rod connected to it back through the back plate, it is usually bronze in colour, the Hydro Gear box has the bypass arm on the side next to the externall brake caliper
SOURCE: My Husqvarna LTD2554 725cc
Oil type used for husqvarna lgt 2554 is SAE 30 (above 32°F) and SAE 5W-30 (below 32°F). -------------- Oil capacity is :--64 oz.---------- ------------ To replace engine oil.Click this link below and see page number 18:--- http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_532428949.pdf ------------ Its the owners manual for your tractor.For filling the engine oil, its mentioned on page number 18. ------------ also to bleed and purge the air out from the transmission, there is procedure.This procedure is mentioned on page number 15.-------- This will help.Thanks.Helpmech.
