20 Most Recent Husqvarna 28cc Gas Line Trimmer Questions & Answers
Dirty air filter, dirty fuel system, ie carb, lines, fuel tank. Poor air fuel mixture srew adjustments.
Husqvarna 28cc... | Answered on Oct 29, 2019
I'll send you a link to the manual.
Husqvarna 28cc... | Answered on Oct 27, 2018
I do not believe this lever comes loose from the carburetor. When a kit is ordered, the lever comes with the carburetor kit.
Husqvarna 28cc... | Answered on Dec 12, 2017
The only blade acceptable on this trimmer is a grass blade. Part number is 578 44 40-01
Make sure there is not debris stopping the head. Try removing the trimmer head and make sure the shaft turns freely. If it does the problem could be either the engine or clutch.
Change the spark plug and carburetor filter.
Husqvarna 28cc... | Answered on Nov 09, 2017
Hi and welcome to FixYa, I am Kelly.
It sounds like the starter cup has failed / broken. See this link: (Page 3 item 14.)
http://weborder.husqvarna.com/order_static/doc/HIPL/HIPL2008/HIPL2008_5450143-15.pdf
However... the pawls on the starter pulley (item 28 above) may have broken.
There is a whole kit for repairing the starter recoil: PN 545180844
That can be found here:
http://cgi.ebay.com/HUSQVARNA-RECOIL-STARTER-KIT-124L-125L-128L-545180844-/150485511147
Your need to remove the starter recoil assy and check for damage. It will be obvious. Just remove the mounting screws and lift it off. It is not difficult. Use the first link page 3 to identify the parts you may need once you do the visual inspection with the recoil removed.
Thanks for choosing FixYa,
Kelly
Husqvarna 28cc... | Answered on Apr 27, 2016
This string trimmer will use .080 trimmer line
Husqvarna 28cc... | Answered on Oct 02, 2014
Hi there your possibly mixing too much oil with the petrol. Try reducing the amount of two stroke oil.
Husqvarna 28cc... | Answered on Jun 13, 2014
Empty the tank and then remove old lines, then get the new lines and place them over the, after that just get the tank full and prime up and hey presto it should start.
I\'m presuming this uses plastic fuel lines.
Husqvarna 28cc... | Answered on Apr 27, 2014
The local Husqvarna agent is the best place to start, e bay is also a source of pattern parts for Husqvarna machines, the part no. for the coil is 545046701
Husqvarna 28cc... | Answered on Feb 18, 2014
clean the gas cap make sure tank vents
Husqvarna 28cc... | Answered on Jan 30, 2014
Do you have the straight shaft version? Brush cutting blades are available from your local mower shop
Husqvarna 28cc... | Answered on Oct 05, 2013
Husqvarna 28cc Gas Line Trimmer Logo
417 questions posted
Top Husqvarna Garden Experts
J. Bradshaw
Marvin
Marvin
dannydoesita
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
View Most Popular
Husqvarna Garden
  • Husqvarna Garden
Most Popular Question
hook up fuel lines
  • Garden
