20 Most Recent Husqvarna 23 Hp 48" Deck Yard Tractor Questions & Answers
Did you carry out the correct bleeding procedure? back wheels off the ground half engine revs, five forward shifts the five reverse shifts, now put unit in bypass and same again, carry this out two or three times until the there is a smooth drive and no noise, if this does not work check the brake disc on the side of the unit is not binding, if this is ok then there is some internal damage, inside the unit there is a alloy centre section with a cylinder block and pistons running on it, if the running face is scarred then oil will leak between the two mating surfaces and there will be little or no power, this will get worse the hotter the unit gets. You can remove the two half's of the unit and replace these components.
Husqvarna 23 Hp... | Answered on Dec 27, 2017
This is an internal leak in the gear box, if there has been no oil leakage there is no value in topping the unit up, you could check the disc brake on the side of the gearbox is not binding, it is adjustable with a 1/2 spanner, if all else fails it is a new unit or a rebuild with new centre section kit.
Husqvarna 23 Hp... | Answered on Dec 18, 2017
If the deck was supplied with grease zerks, they will be located on top of the spindle mandrels. If there are no zerks on the spindle mandrels, the bearing are a sealed bearing and need no greasing.
Husqvarna 23 Hp... | Answered on Dec 12, 2017
Mine is a 2008, I think. I'll keep watching it and see. This is a digital display and it came on at 500 Hr. I found no reset hole, so that must be the answer.
Thanks for the info.
Husqvarna 23 Hp... | Answered on Oct 08, 2016
check your switch for your blades take it off(shut it off)
Husqvarna 23 Hp... | Answered on Apr 07, 2016
Hello eddher:
The Following is a General Instruction File I Made for this Problem. Readjust the Brake Rods to the Original Positions. Now to Adjust the Brake Pads. Tighten the Center Adjusting Nut Until SNUG. Loosen the Adjuster Nut 1/8 Turn and Try the Brakes. If Braking is Not to your Satisfaction, then Adjust the Center Adjusting Nut on the Disc Brake Assembly Slightly (1/8" at a time) Until the Proper Braking is Achieved.
The Brake Assembly is on the Left Side of you Hydro Transaxle.
You can View the Husqvarna Model List at this Site Addy, http://www.partstree.com/parts/ and Click on the Husqvarna Logo. Now Enter the Model Numbers GTH 2448 T in the Search Box on the Left and Click Go. Now Select the Model of the Equipment you Wish to View. The GTH 2448 T 917.279260 has a Hydro transaxle Breakdown.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Husqvarna 23 Hp... | Answered on Apr 06, 2016
Check your drive belt. If you removed the rear wheels, make sure you reinstalled the drive keys.
Husqvarna 23 Hp... | Answered on Jul 10, 2015
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Husqvarna 23 Hp... | Answered on May 10, 2015
This typically indicates a bad spark plug or coil on one side. Possibly the wiring going to the coil or from the coil to the plug. Use a spark tester to test for spark on that side.
Other less fun problems are the valves on that side need adjustment.
Husqvarna 23 Hp... | Answered on Mar 14, 2015
starter silinoid bad replace but first jump the starter to make sure its not bad
Husqvarna 23 Hp... | Answered on Sep 11, 2014
it could be that the solenoid is bad i would try that they are realtivaly cheap and easy to put on make sure to unhook battery
Husqvarna 23 Hp... | Answered on Aug 17, 2014
What are the size of the streaks? and where in the 48 inch swath?
Husqvarna 23 Hp... | Answered on Aug 06, 2014
check for a area of the wire insulation that has been wore off against the frame or body of the mower. sounds like a electrical short. it may be a very small spot that's all it takes so check well
Husqvarna 23 Hp... | Answered on Jul 14, 2014
One or more of the pulleys are worn and need to be replaced. The method I use is to pull the belt away and hand-spin each pulley to see which one has a grinding sound or loose feel. (A new pulley will feel rock solid and have no sound when you spin it.)
Husqvarna 23 Hp... | Answered on May 25, 2014
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
176 questions posted
Top Husqvarna Garden Experts
Marvin
Marvin
dannydoesita
Wayne McNeil
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
View Most Popular
Husqvarna Garden
  • Husqvarna Garden
Most Popular Question
husqvarna yth24v48ls leaves streaks
  • Garden
