In hp color laserjet 3500 printer,Color print is not proper. I have changed all cartiage & Transfer kit but color print is not coming properly.
Please get solution this problem
my mail id : [email protected]
Try in on printer to do full calibration!!! Because printer do quick but you need to do full calibration
Hi!
If you could possibly manage to access the machine status menu and have it print to check the drum's life, fuser life, developer, etc.. pls refer. Kindly replace the toner cartridge accordingly use the menu settings when replacing any color if needed. Please print solid image or block in each color Cyan, Magenta, Yellow and Balck. Well see if what color causing the problem. Please let me know the print result it may be; washed out or too light, too bright or black, double image, or not clean. Don't hesistate to contact me again about the result.
Best regards,
Rosener Guyano
Can you be specific about problem!
Not enough color, which cartridge!!!
reset transfer kit hp laserjet cp4025
