SOURCE: Canon MP830 - Outgoing fax dialing not connecting
Are you plugged into the LINE port of the fax machine?
SOURCE: Receiving and sending faxes
if the fax is connected to the same line and you have a phone connected to the fax you need to make sure you connect the line from the socket at wall to the correct socket on the fax you can check this by looking at the point the line is connected on fax there should be two connectors one says line and one says tel.. the line in goes to the line socket and your telephone goes into the tel socket.. if you have them the other way round it cant connect properly..on the front display panel make sure you have it set to the auto setting or tel fax mode for receive.. if you have it to auto it will check the incoming call if it is a fax it will send it through if not it will ring till you answer.. if set to tel/fax mode when it rings you will have to answer the phone and manually press start if you hear it is a fax.. Good luck A
SOURCE: OKIFAX 4580 - Comms error
The printer costantly shows replace drum soon error.
How do you get rid of this.
Theo
SOURCE: How do you change (where is it) the drum in the
rwhen you replace the toner youare putting it in the drum cartridge.the whole black unit gets replaced.lift it up to remove.when you replace it also install a new toner cartridge the drum resevoir will be empty when
new it will need a new toner cart. to fill it now you need to reset the drum counter.push select function
button,to the right number 8 or 9 says counter display
push it,screen will will say drum count reset? push yes arrow screen will say are you sure? push yes
tada! if it now says replace toner open the white cover
over the drum then reclose it a motor will run for about 30 seconds its adding the new toner to the
resevoir you may need to do this about 3 times or until add toner message goes away
