20 Most Recent
OKI C5200n Laser Printer Questions & Answers
Black text or black print is faded in a 2" vide area
Although the drum life is at 65% it could still have a problem. It could be that the end of the drum is starved of toner or there is lumpy toner in the drum. Take out the black drum and give it a good shake then a gentle one to level the toner out and refit. Had the same with a canon unit 2 weeks ago. If still no good then a new drum is required. I bet you are using recycled drums!!
We have an Oki 5200c and are printing color
Wrong size paper or paper setting in the software settings. Or the dreaded plastic gear/roller cam has warn down. You'll notice some parts are plastic designed to ware out.
We have recently bought a second hand OKI C5200
One or more of the drums may be defective. Swap the black with another color and print a document. If that color printed the charectors ok, then continue the test with the other drums each taking a turn in the Black drum position until you find the bad drum.
127 borderless
You cant. laser printers (or led like oki) or more specifically dry toner electrostatic printers always have a margin to prevent the paper from jamming. the only way to print "full bleed" is to put paper in that is bigger than what you need, print the image, and trim it down.
Why does yellow not print on oki c5200?
The fountain under the yellow cartridge could be dried and clogged (assuming the cartridge is not dried up from too infrequent use and is not empty. If you stuff all around the fountain with rags and then gently force water into the fountain using a syringe you might be able to clear the ink passageway and restore yellow in the machine. Servicing the other fountains might be in order, too, since one clog is likely to be followed by others. Remember to use the printer more often to prevent such cloggingg. Also, you could try the built-in printer head clean function before trying the manual cleaning; but, generally, when it gets to the point of zero ink delivery, it's already to late to clear the ink clog with fresh ink, which is what the self clean feature does to try to dissolve the clog and restore ink flow to the fountain.
What are feed rollers and pads
Feed rollers are the rubber tires in your printer that pick up paper. They spin in the direction of the paper movement. They wear out over time due to use, and will need to be replaced. Pads are usually used for seperation and can be a flat peice or a round roller. They sit under the pickup roller and stop more than one piece of paper from being fed.
