SOURCE: im trying to program my Pro-70 Hyperscaner
Turn the unit on, Press MANUAL, enter the channel number, then press MANUAL, enter the frequency you want including the decimal point, then press E to enter, if you make a mistake, press CLR twice to erase....hope this was helpful...You can get your frequency's for your state at www.RadioReference.com .....
SOURCE: need programmer codes for a pro-64 hyperscan
Programmer codes? If it's the operating frequencies for agencies in your area that you're looking for, you can find them and a lot of other useful scanning information at:
Need the operating manual for your scanner? You can download and print it here:
http://support.radioshack.com/support_electronics/36549.htm
Bill B
SOURCE: I have a radio shack
You can initialize the scanner to delete all information that you've programmed into it and return it to its original factory settings. To do this:
1. Turn the scanner OFF, then turn it ON again.
2. Press and hold down the CLEAR key and insert a pointed object, such as a paperclip or the point of a pen, into the RESET opening in the back of the scanner, and press the button inside the opening.
3. Release RESET. When information reappears on the scanner's display, release the CLEAR key.
NOTE: You must release the RESET button before releasing the CLEAR key.
Also note that this procedure may not be necessary. Programming a new frequency into a channel automatically deletes the frequency previously stored in that channel.
Bill B
Listening in since the 60's
Testimonial: "Perfect solution for what I want to do. Thank You"
SOURCE: I need a manual for
Your manual is no longer available as a single document, but you can download and print individual sections of it, at no cost, here:
http://support.radioshack.com/support_electronics/28537.htm
Bill B
