20 Most Recent Plantronics Explorer 220 Bluetooth Headset Wireless Headset Questions & Answers
2answers
Plantronics 2XX pair code
The pairing pin should be 0000, most bluetooth device's use all 0's.
Hope this help's.
10/21/2022 5:04:28 PM • Plantronics... • Answered on Oct 21, 2022
2answers
I need the passkey for Plantronics Explorer 220 Bluetooth Headset
Most passkey are 0000 try thay
11/21/2017 6:29:24 AM • Plantronics... • Answered on Nov 21, 2017
0answers
4answers
Bluetooth "device out of range or powered off"
I had lots of trouble too. I thought it was my phone. Well here's what you do. First off remove the device completely from your phone. Turn off the phone and take the battery off so it can re-boot. When the phone is powered back up put your bluetooth in pairing mode and get it back on your phone. It should connect without any problems. Now....here is the trick. When you want to disconnect the device(bluetooth) from your phone don't turn it off on your phone. Shut the actual power off on your bluetooth. The phone will recognize this and disconnect the device. The only thing left on your phone will be the bluetooth icon. Being the icon still on your phone it is still in discovery mode and can overtime use up your battery life searching for a device. This is when you can go to your phone and turn off the bluetooth. On your NV 2 go to your bluetooth menu and just use your left softkeyto turn it off. Now there is no connection whatsoever. And to turn it back on do the opposite. Go to your bluetooth menu and turn on your bluetooth. You will see the bluetooth icon. Now you power up the bluetooth and it will connect as soon as it get the signal. This took me 2 weeks of trial and error and other stuff but I am happy now and I hope this solves any bluetooth problems...
5/17/2017 2:55:12 PM • Plantronics... • Answered on May 17, 2017
Bluetooth wont charge or power on. when charging
Indicator Lights: 1.Headset Status Headset Indicator Light2.Powering on Steady blue, then intermittent flashes(changes to standby mode)3.Powering off Red appears and goes off4.Standby Blue intermittent flashes 5.Charging battery Red solid light. Light indicator turns off whenbattery is fully charged and headset is off.6.Low battery Triple red flashes7.Pairing mode Blue/red alternating flashes8.Missed call Purple flashes. Press the call control button to cancel flashing light.9.Incoming call Triple blue flashes when ringing.Power on and off:1.Turn on the headset Press and hold the call control button until theindicator glows blue. You will hear ascending tones.2.Turn off the headset Press and hold the call control button until theindicator glows red. You will hear descendingtones. When power is off, indicator stays off.If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.Good luck from Headsets Direct!
6/3/2016 5:56:31 PM • Plantronics... • Answered on Jun 03, 2016
I have had this bluetooth for a while but never
The default pass code is "0000."
Here's how to pair it with the default pass code:
  1. Turn the Bluetooth on and hold down the button until the light turns solid.
  2. Put the phone in discovery mode or search for a Bluetooth device.
  3. Pair the Bluetooth to the phone and enter the pass code "0000"
2/20/2016 5:04:11 AM • Plantronics... • Answered on Feb 20, 2016
Can you adjust the size of the earpiece?
no you can't just bought a samsung wep301 it does not fall off they only fit people with bigger ears I have small and skiiny ears
11/30/2015 5:53:33 PM • Plantronics... • Answered on Nov 30, 2015
Plantronics Explorer 220 Bluetooth Headset Wireless Headset Logo
623 questions posted
Top Plantronics Radio Communications Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Plantronics Radio Communications
Most Popular Question
get into pairing mode
  • Radio Communications
