20 Most Recent Radio Shack Pro-97 Handheld Scanner Questions & Answers
Problem with Pro-2066 scanner not receiving local
It is difficult to explain in simple terms but I will try. Google rebanding. Some radios can have their firmware updated but I don't think your PRO 2066 can. Channel numbers and frequencies preprogrammed into your scanner have changed over the past few years. When a data signal says go to channel X that channel is now Y, but your scanner is still looking for X Hope this helps
8/26/2017 3:57:19 AM • Radio Shack... • Answered on Aug 26, 2017
Want the frequency codes to the corpus christi tx police
See previous question- need a digital trunking scanner, need a Radio Reference membership (free or paid) and go to this link: https://www.radioreference.com/apps/db/?sid=17
5/1/2017 7:27:52 PM • Radio Shack... • Answered on May 01, 2017
Need a picture of the usb programming for pro 97cable
You need RS232 drivers. Try BatLabs dot com. You can't make one from just a cable.
5/1/2017 7:17:28 PM • Radio Shack... • Answered on May 01, 2017
Police frequencies michigan
Hi, must have a digital trunking scanner first and foremost if you want to monitor the state radio frequencies. You much has a ham radio license or 'permit' to use the scanner or even have the scanner in you car. You can sign-up for a premium membership at Radio Reference dot com and it will set you up with direct loads of frequencies and talkgroups. Here's a link to help you: https://www.radioreference.com/apps/db/?stid=26
5/1/2017 6:24:45 PM • Radio Shack... • Answered on May 01, 2017
I turn on my pro -97 Handheld Scanner and it displays all channels are locked
Turn the scanner on and make sure that you don't see a "key" in the display- if you do, you first have to press and hold the key LOCK button until it beeps and allows you to use the keys. press 'manual'. press and hold 'L/O' 'lockout' for 3 seconds and it will unlock all locked out channels. now press 'scan'. if you have nothing, then press 'scan' again and press each one of the number keys to turn off and to switch on the scanning banks. Okay? Let me know if you need more help.
5/1/2017 6:19:55 PM • Radio Shack... • Answered on May 01, 2017
WHERE IS THE BUTTON i PUSH TO UNLOCK ALL CHANNELS
turn the scanner on. press 'manual'. press and hold 'L/O' 'lockout' for 3 seconds and it will unlock all locked out channels. now press 'scan'. if you have nothing, then press 'scan' again and press each one of the number keys to turn off and to switch on the scanning banks. Okay? Let me know if you need more help.
5/1/2017 6:17:55 PM • Radio Shack... • Answered on May 01, 2017
All channels locked out
Press scan, then press a number button and it will scan that bank -pick a number from 0-9 and it should scan that. If you did truly lockout everything hit 'manual' then hold down the L/O Lockout button for 3 seconds and you'll hear a beep- that should unlock everything.
5/1/2017 6:11:27 PM • Radio Shack... • Answered on May 01, 2017
Radio shack pro 405 scanner
Here is your downloadable owners manual with complete instructions. Radio Shack 20 405 User Manual
10/8/2015 5:47:20 AM • Radio Shack... • Answered on Oct 08, 2015
How do i reset my radio shack 197 back to factory
The information is found on pages 90-92 of the owners manual, which you can download for free in PDF format from the link below. Remember: Erasing like this is permanent, make SURE its what you want to do. http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/2000197_PM_EN.pdf
8/2/2014 6:25:24 AM • Radio Shack... • Answered on Aug 02, 2014
My screen quit working possibly because it is hot. How can I fix it
It would be cheaper to buy a new one than to fix the broken one.
6/15/2014 1:22:04 AM • Radio Shack... • Answered on Jun 15, 2014
0answers
0answers
0answers
Radio Shack 16a Handheld Scanner
I had the same problem and when this happens I just press and hold the scan button until it beeps and begins to scan again.
1/6/2014 8:50:53 AM • Radio Shack... • Answered on Jan 06, 2014
Cant pick up stations
Most police stations are using the new motorola trunking units, they are on encrypted custom band channels and you will not be able to hear them. All police helicopters are equipped with them. All i can hear where i live is Fire dispatch, I cant even hear the fire fighters responses .
11/29/2013 10:13:09 AM • Radio Shack... • Answered on Nov 29, 2013
2answers
POLICE SCANNER FREQEUNCIES
finding the frequencies is pretty straight forward...
here's one easy solution..The simplest way is to GOOGLE.
go to google.com
enter "radio frequencies" and your county name and state..
you'll get the links to posted municipal services' radio freq's.
Then simply enter them into your scanner memory...
If you need the "10 codel" definitions, you can get those too so that you'll fully understand what all their abbreviations mean...
Have fun..
10/16/2013 7:51:45 PM • Radio Shack... • Answered on Oct 16, 2013
Channels locked
reset your radio.
10/9/2013 8:30:53 AM • Radio Shack... • Answered on Oct 09, 2013
Radio Shack Pro-97 Handheld Scanner Logo
270 questions posted
Top Radio Shack Radio Communications Experts
John
John
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Radio Shack Radio Communications
Most Popular Question
turn pro 97 handheld scanner displays
  • Radio Communications
