Try to set your printers configurations fatory default 10. Maintenance> Of clear Of setting> Of all Of setting[OK]
In the service menu (TECH MODE): MENU> Of data Of setup > Of clear of count > Of clear Of all CNT
SOLVED IT! - PROBLEM: I'm using a refilled toner / NOT original Samsung (supplier: Peach, Switzerland) - SOLUTION: 1. Remove the toner 2. Simply put a tape over the four metal contacts on the backside of the toner 3. Insert the toner - It will now print, the printer says "low toner" & the LED status light is red - just ignore! It still work well.... - EXPLANATION: the chip (behind the four contacts) seems not be needed. I used a compatible 3rd party toner (Peach, Switzerland) - Observation: The refilled toner worked well for the first 2-3 weeks, then suddenly I had this error message.
Generally this message occurs when using a generic toner cartridge that has the incorrect micro chip counter on it. Is the toner cartridge generic or genuine? In either case it needs to be returned for a credit or replacement.
Putting a genuine cartridge will rectify the problem i feel.
Good day Sir, In Samsung scx-4300 display Toner exhausted the machine will stop to prevent serious pollution or breakdown of the machine. Replace the toner cartridge with a new one and make sure it is genuine to prevent toner errors.
My
laser Printer shows a message and do not prints any document. When i
try to print any document. My printer shows a message "Toner Exhausted,
Replace Toner". Plz tell me how can i solve my this printer's solution.
When toner exhausted error comes up, To prevent serious pollution or breakdown of printer, the printer stops printing.Replacing the toner cartridge with another one will solve the problem. If you have another toner, not necessarily a new one, try to change it with the old one and then try it to print. if it persists, then you may need to get a new toner.
yes its its new & orignal samsung toner
Is the new toner an original Samsung toner?
