Chargingligth is also on, but I've checked, at the battery with voltmeter, everything seems to be ok, but missing some lights in my dashboard..
You said the charging light is on? That indicates that your alternator is NOT charging.. You said you checked at the battery.. Was that while it was running? How many volts is it producing? Running it should have about 13.5 to 14.7 If not, your alternator is bad.
Testimonial: "got about 14,05 volt with engine running.. everything was fine until I moved the gas tank backwards at the seat.. my guess, it some wire are broken or something."
Did you repair or replace the one you had? If you repaired it, you probably didn't attach one of the wires. If you replaced it, there are two possibilities: 1) the new unit was bad or 2) the new unit is not for your vehicle.
SOURCE: Flashing amber light, no battery recognition or power meter
Bad DC IN (probably after last repair)
One side of the DC Jack is not getting ground connection.
This happens when one of the negative leads are not connected. Simple fix for skilled tech
SOURCE: dashboard lights
Their wiring can be something .The circuit boards short out and the lights on the right front where on with the left rear lights.
SOURCE: Interior lights won't turn off 1999 BuicK LeSabre.
yes there is a relay switch in engine compartment or under dash
