M
Mpiyakhe Petrus Mkwemde Posted on Feb 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hp laserjet 4345 MFP is flickering logo on screen only and it's not turning on. It also showing two green light and red one below. it s not working at all
Red light instead of green once only, its flickerting the logo on screen without showing the sreenfully. what is the problem?
Tammie Duggan
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 57 Answers
  • Posted on Apr 20, 2019
Tammie Duggan
Expert
Level 2:
New Friend:
Night Owl:
Answers
57
Questions
Helped
25720
Points
165
5 Related Answers
seeker5211
Seeker5211
  • 1089 Answers
  • Posted on Jan 29, 2010
SOURCE: Hp LJ 4345 mfp vertical line down printed copies
Dirt.
Open the ADF, the top of the scanner/copier.
The ADF glass is the thin strip of glass on the left. Damp cloth with windex or any glass cleaner. Scrub the strip of glass.
Anonymous
  • 16 Answers
  • Posted on Feb 15, 2010
SOURCE: My HP 4345 mfp will not boot up
When the memory counts up when turning mfp on, hold down the 6 button until all three lights on left of panel light up, then using the 3 button to scroll go to COLD RESET and touch 6 button to select. If that doesnt fix ya then you may need a hard disk drive
indus3
Hans De Becker
  • 212 Answers
  • Posted on Apr 21, 2010
SOURCE: I get an error in HP LaserJet 4345 MFP printer,
a 49.xxxx error on an HP means that there is an issue with one or more hard disks. you can try to re-initialise the hard disk(s) by rebooting the printer while holding the green button. when the three leds are lit, release the green button, and navigate using the numerical buttons until you see "initialise hard disks" on the display of the printer. confirm by pressing the green button again. if all goes well, your printer will take two minutes longer than usual to boot. if you still get the same error afterwards, you need to replace the disk.
Anonymous
  • 47 Answers
  • Posted on Feb 28, 2011
SOURCE: I need to swap the swing plate inside a HP
I was able to find a video tutorial for this problem at http://www.youtube.com/watch?v=6MsQM4xkKDY&feature=related
Hopefully it will be able to guide you through the necessary steps to change the swing plate. Good luck!
Testimonial: "Thanks for the guide!"
Anonymous
  • 184 Answers
  • Posted on Aug 30, 2011
SOURCE: error code 13.20.00 for hp
Hi!
According to HP service manuals, the error you described is in the category:
JAM INSIDE TOP COVER AREA
and more specific:
The pre-feed sensor, the top-of-page sensor, or the fuser-delivery
Those are the points where some paper pieces or even dust can be stuck.
Hope it helped,
Bogdan
Hp laserjet 1536 dnf MFP. How can I repair document feeder?
how to fix and repair the adf doc feeder Q5997A hp laserjet ...
? 1:36
https://www.youtube.com/watch?v=lpTj4jiLaY8
Dec 12, 2011 - Uploaded by BrokenPrinter1
Parts Available @ BrokenPrinter.com how to fix and replace the rollers on a hp laserjet 4345 mfp and color ...
Fixing Paper Pick-Up Issues - HP LaserJet Pro M1212nf ...
? 5:40
https://www.youtube.com/watch?v=ZXtAhSDYqyU
Jan 23, 2013 - Uploaded by HP Printer Support
Learn what to do if your HP printer does not pick up or feed paper from the ADF when you do have paper loaded, and a Doc feedermispick error message display... ... FIX YOUR PRINTER: ERROR: Printer Does not Grab Paper fromTray ... Kit m3027 mfp- Kit Hp m3027 mfp - Kit Mantenimiento m3027 mfp ...
'Document feeder mispick' Message Displays on the Control ...
Hp laserjet 4345 mfp cannot photocopy anything because the startup button has a red light
Hi Bridgette.
The red light on the startup-button indicates that the machine is not ready for a photocopy. Usally there is something stuck in automated document feeder (ADF). Take a close look and see if can see something in the paperpath. If no luck, try pushing a A4 sheet manually through the ADF and see if something comes out with the sheet. Usally there is a small piece of paper, a paper clip or a staple stuck in the ADF. If nothing found in the ADF, the Scanner Controller Board is probably broke, and needs to be replaced. Good luck.
I have an hp laserjet 4345 mfp which gives error code 58.04.Please help me
Hi
Follow the below solution
Turn the MFP off, and then turn the MFP on.
58.4 = Engine power supply
Check the power supply connections
Replace the air-temperature sensor.
See Main fan (FN101) and reversing unit
do rate my solution
1helpful
I need to swap the swing plate inside a HP Laserjet 4345 MFP could someone please show me how it is done?
Model HP LaserJet M4345 MFP The printer displays
You've done everything but replace the formatter.
Can you look at the Event Log? Look for a 79.xxxx error. That is definately a formatter.
Is this a solid error, meaning does it appear when printer inits?
Remove the DIMMs and flash memory and network cable. And reinstall one by one until error reappears.
Do you have another 4345 that you can "borrow" a formatter from?
1helpful
HP Laserjet 4345MFP Backlight on printer display does not light. Counts up the 256MB memory then HP logo (3 sizes) appears (just visible) The 3 lights keep cycling on the display. Thats it, does nothing...
HP Laserjet 4345MFP
The 3 lights keep cycling on the display. Thats it, does nothing else.
It has been left overnight and continues to display the logo and cycling 3 lights.
Rear DC Cont Fan is turning. No other fans or activity with machine.
When ADF/scanner/mfp or hard disk are disconnected it does recognise this and throws an error and asks for reboot.
I have tried cold reset, nvram init. and hard disk init. but no difference.
Your thoughts?
1helpful
2answers
I get an error in HP LaserJet 4345 MFP printer, 49.ff95 error, Tunr off and the turn on
9helpful
2answers
Paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
1helpful
My HP 4345 mfp will not boot up, the HP logo keeps flashing on the screen
5helpful
Dirt.
k24674
Grand Canyon Tech
Grand Canyon Tech
