SOURCE: Lexmark X4850 paper jam
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
SOURCE: Lexmark X6570 printer - Cleared
Ok, the paper jam could be due to one of the following:
First try a hard reset - unplug printer from power source, wait a minute and replug. If it still does not work, uninstall the driver, reboot PC and reinstall (or download latest version from lexmark.com.
If there is no bit of paper or
debris stuck in the rollers, it would indicate something more serious,
and in need of servicing. If your machine is under warranty, I suggest
you take it back to the shop and get it replaced.
If your warranty
has run out, then you'll either have to get it serviced or buy a new
printer (whichever works out cheaper for you)
Hope that helps!
SOURCE: paper jam lexmark x3470
#2 works for an x3470, but jostling the small cylinder that accepts the paper (nudge it gently toward the printer) seems to be what pulls back the microswitch...
SOURCE: Lexmark S405 Paper Jam
Hello there ok
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
http://www.printertechs.com/tech/mkinst/mk-1300-5fuser1.php
