20 Most Recent Lexmark E232 Laser Printer Questions & Answers
Installing Lexmark E232 in Window 10 connect via USB Printer not found.
Windows 10 is Plug and Play so connecting the printer by USB cable, Win 10 should auto-discover it once it is powered up.
If the printer not found message happens after connecting the cable and then auto-discover faults, might try a different USB port on the PC or a different USB cable.
If the error occurs when scanning for new devices, pretty much the same thing goes.
Or the printer has an issue and will not communicate over USB for some reason. Perhaps a factory reset of the printer settings, to clear some erroneous setting, would help.
Last suggestion: make sure your Windows 10 Update is run to take all the latest patches (may take several Update/Reboot cycles to get them all), and that the OS is properly licensed and activated with a valid license key. Some features are disabled when the OS is not activated. Anti-virus software might be blocking the software install needed. If the printer came with a disc, connect the printer, power it on, insert the disc and see if it will install a driver.
The web site shows this printer is discontinued so maybe it is old enough that they didn't produce a Win 10 driver. Windows Update should pick one up if it is available as most HW manufacturers publish their drivers through the Windows Update process.
https://www.lexmark.com/en_us/printer/2236/Lexmark-E232
11/27/2021 7:24:48 PM • Lexmark E232... • Answered on Nov 27, 2021
When I plug in the E232 my keyboard & mouse stop working
change your IRQ settings in your setup
12/28/2017 1:14:20 PM • Lexmark E232... • Answered on Dec 28, 2017
Black lines on paper
Replace the drum
9/23/2015 4:09:47 AM • Lexmark E232... • Answered on Sep 23, 2015
How do I correct black smudges when printing?
If the smudge marks are down the edges of the paper, the PC Kit needs replaced.
2/23/2015 1:22:16 AM • Lexmark E232... • Answered on Feb 23, 2015
Page count
The E232 cartridge uses a chip to set the page count on the printer. To reset this you need to replace the chip on the cartridge. Your friendly cartridge remanufacturer has access to the chip. They can source one for you.
10/3/2014 2:22:25 AM • Lexmark E232... • Answered on Oct 03, 2014
0answers
0answers
What does the symbols on the printer mean
If your intrested of that find a service manual or a user manual and you will find out , but if i suspect we'll your printer has a problem whith the main board a service man might try to change the bin info located on the chip from pannel
5/18/2014 10:08:46 PM • Lexmark E232... • Answered on May 18, 2014
0answers
What are the 5 light and symbols on the lexmark e260d printer?
Hi. Here is a link to the products user-manual. Please read page 15 about led indicators... http://www.lexmark.com/publications/pdfs/2007/e26x/v14843035_en.pdf
3/9/2014 11:57:54 AM • Lexmark E232... • Answered on Mar 09, 2014
0answers
2answers
Orange light still flashes after new cartridge
Can you tell us which lighton the modem has a flashing orange light? The operator panel lights meandifferent things, depending on their sequence. Please tell us more about it sothat we can assist with your issue.
For further assistance, please contact Lexmark Technical Support
10/3/2013 3:31:47 PM • Lexmark E232... • Answered on Oct 03, 2013
Code error
Try to install the latest drivers. It may solve the problem.
9/23/2013 1:40:48 PM • Lexmark E232... • Answered on Sep 23, 2013
0answers
5answers
Lexmark E232 - Tray-1 Paper Problem
Have the same problem after 1,500 pages! This was Lexmark's solution (and it worked)...
Take the paperfeed tray out and you will see a red lever , press it
downwards and you will see the paperfeed rollers coming down , you need to
pull the rubber tyres off those rollers and place them inside out over
them and then try printing any document. Check the paper weight and
the paper type you need to use 20 pounds regular paper and try runnning a
can of compressed air inside the machine.
If rubber tyres on the paper feed rollers are totally worned out you
need to replace the feed rollers.
7/17/2013 7:55:44 AM • Lexmark E232... • Answered on Jul 17, 2013
Leaving a white line
It could be of the toner is bad or the laser scanner is dirty.
3/4/2013 2:38:28 AM • Lexmark E232... • Answered on Mar 04, 2013
Lexmark E232 Laser Printer Logo
272 questions posted
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
E Lexmark
  • E Lexmark
Most Popular Question
lexmark e232 keeps telling me paper
  • Office Equipment & Supplies
