Canon DR-9080C. When I close the lid, I have to hold it down otherwise I get P00 error. If I do not keep downward pressure on lid, paper jams in output rollers. With pressure on lid, it scans fine.
As long as I keep downward pressure on the lid, it scans fine. Otherwise, the paper jams in the top, output rollers.
You will need to replace the upper and lower reading and registration rollers. Sometimes you can get by with only the upper rollers which are much easier than the lower ones. These are the black rollers in the feed path...not the consumable rollers. If you are mechanically inclined, you can probable do this yourself. Give me a call if you need a technical walk through. http://www.scan-r-store.com
You can't post conmments that contain an email address.
This is a common problem in 9080C. When the top cover is closed, the sensor sends light and it is reflected thro the black cover in the bottom. Then the scanner assumes the cover is closed. Any obstruction is treated as P00 error. You will notice three small oval & round shaped clear plastic. Clean them with a brush and ensure the edges are clean. Light goes thru one side and come thro the other, which is sensed by the unit placed in the top cover.
A few easy things to try. First off, have you power cycled the unit since checking for a paper jam? Often that will clear false errors.
If not, look for the sensors. They should be somewhere along the paper path, and consist of a plastic lever that will be pushed down as the paper moves past them. Usually these levers have springs attached - if the spring comes off, it will register a paper jam. You'll probably have to take off some of the housing to get to them.
I'm not sure this will help much, but since I found it I'll post it. The user's manual:
http://edocutek.com/Manuals/DR6080_9080C_UG.pdf
If the sensor needs replaced (most often due to something simple like a piece of plastic breaking on it), you can order new sensor PCB assemblies (sensor and its small control board) here:
http://www.precisionroller.com/manufacturers/canon-dr6080.html
They also sell a parts manual, but it's a bit pricey.
If there is already a document inside the scanner while powering on, you get P00. Remove any paper inside the scanner. If there is no paper and you still get P00, then thee must be a small shred of paper blocking sensors. Gently blow air to clear it.
S. Mohan, Chennai, India
There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
S. Mohan, India
P00 is paper/document already present in the Scanner and scanner not initialised. You will heat two beeps. Open remove all shred os paper. C01 is cover open, close it firmly
S. Mohan, India
Canon error numbers are logical! Error starting with 'P' is paper related. If there is already soem paper inside the scanner while inititalising, u will get this error. Check for shreds of paper in the paper path. (Error starting with 'C' is Cover and 'E' isn Engineer reqd)
S. Mohan, Chennai, india
to check the page count install the driver and setup the scanner as a "scanner device" on your computer. Once you have done that , go to the "control panel" than "scanners and printers". Right-click on the device that says "Cannon DR-9080C" and select "properties". The device information will appear, than select the "counter" tab on the information box; the scan count will be listed.
