20 Most Recent Canon DR-7580 Questions & Answers
2answers
Bar Code Used as Document Name
It's not really an issue with the scanner. The scanner will pick up the image and convert it to whatever you want, but your backend software is what you'll need to mess with for this. Any form recognition software will work (Form Storm, ABBYY FormReader, etc.)
1/18/2015 8:06:02 PM • Canon DR-7580 • Answered on Jan 18, 2015
Capture barcode at scanner Canon Dr 9080C
You will need to purchase the CD "Canon Barcode Module III" and install it on your computer: Mfg. Part: 1922B001 Then you can select it in Canon's document scanning software/Capture Perfect. Scan-R-Store
1/18/2015 7:48:17 PM • Canon DR-7580 • Answered on Jan 18, 2015
2answers
How to reset counter on canon dr 7580
You need to run Qumatool to reset the counter S. Mohan
1/18/2015 7:35:51 PM • Canon DR-7580 • Answered on Jan 18, 2015
3answers
Canon DR-7580 will scan first 12-14 pages rapidly
Your hard disk must be almost full. Direct the scanning software to send data to a hard Disk location where you have enough space.
S. Mohan, India
1/18/2015 6:05:35 PM • Canon DR-7580 • Answered on Jan 18, 2015
3answers
SAYS STAPLE DETECTED BUT NO STAPLE
Try cleaning the staple detection sensors in the machine. Most of the time if you blow air gently into the machine to clear dust from the sensors.
1/18/2015 5:28:53 PM • Canon DR-7580 • Answered on Jan 18, 2015
2answers
STAPLE DETECTED
Try turning off the Staple detection option in the settings.
1/18/2015 5:17:05 PM • Canon DR-7580 • Answered on Jan 18, 2015
Canon dr-6080 getting an error a01 and won't feed
As per the manual it is "In the event of a pick-up error, the document was fed to the front registration sensors." Clean all the Sensors and try. Use isoproyl alcohol only. S. Mohan, India
12/27/2014 6:47:25 PM • Canon DR-7580 • Answered on Dec 27, 2014
Installer captureperfect
Not sure as to what you are asking as there is not a question here. As you asking about locating an installer application for Capture Perfect??
8/25/2014 9:07:50 PM • Canon DR-7580 • Answered on Aug 25, 2014
Scanning half a page
You will need to check your page settings. As each program is different, the page setup will generally stay the same. It will also change if you are scanning at 0, 90, 180, or 270 degrees as well.
8/25/2014 9:04:39 PM • Canon DR-7580 • Answered on Aug 25, 2014
How to replace sensor in DR7580?
Which sensor do you need to replace? These machines have several sensors throught the machine that assist with lifting the tray, watching for staples, and even double feed detection.
8/19/2014 7:50:50 PM • Canon DR-7580 • Answered on Aug 19, 2014
Line down middle of paper
Sounds like you have a scratched lens. If you have another unit, try replacing the lens from that one. If you do not, you will need to replace the complete unit or see if you can find one on Ebay.
8/19/2014 7:48:41 PM • Canon DR-7580 • Answered on Aug 19, 2014
Paper Feed Problem
Try changing the exchange rollers (Feed, pickup, and retard rollers)
8/12/2014 6:52:17 PM • Canon DR-7580 • Answered on Aug 12, 2014
2answers
Change orientation on canon dr-7580 scanner
Two step process, scan and save the image, then print and select landscape
7/6/2014 5:33:47 PM • Canon DR-7580 • Answered on Jul 06, 2014
2answers
Won't lift
Check the roller cover. If the roller cover is not firmly closed it will cause a feed error.
I opened and firmly closed the roller cover until I hear it click.
After that it lift the tray to scan..
12/23/2013 3:37:49 AM • Canon DR-7580 • Answered on Dec 23, 2013
0answers
0answers
66 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
DR Canon
  • DR Canon
Most Popular Question
error p00 display no paper jam found
  • Office Equipment & Supplies
