Yes you will need to replace your fuser however, it is best to order a maintenance kit P3305's are notorious for eating pick rollers and separation pads. Be careful though and make sure you get the right voltage 110 (Continental US)or 220 volts (European) Prices range from just over a hundred to the two hundred something range.
I work with this model printer a lot and it has a fairly high failure rate so hopefully it works out for you
The fuser is bad. Needs to be replaced.
