That error usually indicates the ribbon is not loaded properly in the carrier. Please double-check to ensure the spools are inserted in the spaces with the matching color (i.e. - blue to blue; orange to orange), and that the ribbon is threaded the LONG WAY around the carrier, such that it passes over the silver-metallic rollers. Note also that the ribbons MAY have a spot of glue on them from the factory that is there to keep it from loosening or unrolling during shipment. After threading the ribbon properly, turn the take-up spool by hand to ensure that ribbon material is moving smoothly from the feed spool, and is not stuck.
SOURCE: HDP600 print ribbon will not align properly.
If your looking for a new unit www.getthatpart.com has them at a very good price ($2,500.00)brand new sealed in box
The print Ribbon is not installed properly or has been damaged.".
If you're certain the ribbon & film are loaded properly, and in the correct carriers, the next thing to try is a new ribbon and/or new film to see if the error is consistent. If new materials don't solve the issue, then it seems likely you're having a hardware fault of some kind, which would require service.
If you're located in the USA, we are a servicing dealer for Fargo, and can help with out-of-warranty service. If outside the USA, or if the unit is still in warranty, consult your local dealer.
Safe-Card ID Services
Charlotte, NC USA
https://www.safecardid.com
when power on the printer the printer coming leftside and showing hardware alarm
check ribbon
+0306ne -007 000
000000128 +0304
error in display. how to rectifie the problem
