20 Most Recent Fargo Pro L ID Thermal Printer Questions & Answers
Hi Kandi, My name is Tom. First, I need to know
the cable should have a usb at one end and a mini usb at the other what is in the ram card will be sufficient as the pc downloads any printing into the card in the printer follow the user manual or download that manual from the manufactures web page basic connecting is to turn the printer off, connect the cable then turn the printer on ( make sure that there is a power supply for the printer) go to the control panel and click on add a printer if you have a disc install it when requested and let the installer wizard to the job
6/21/2017 1:58:49 AM • Fargo Pro L ID... • Answered on Jun 21, 2017
Why my Fargo ProL Printer is not printing my Card Back Clear?
Hi, Its not clear what you are saying. First, what kind of ribbon are you using for printing, and what kind of lamination ribbon are you using? what are you trying to print on the front and back?
2/17/2015 2:36:18 PM • Fargo Pro L ID... • Answered on Feb 17, 2015
Why my Fargo ProL is not printing Edge to edge?
it depends how much edge to edge you want, its a direct to card printer and will not print all the way to the edge 100%. you can get it close by adjusting the horizonal settings, but to get true edge to edge you need the HDP printers.
12/20/2014 10:28:58 AM • Fargo Pro L ID... • Answered on Dec 20, 2014
My fargo Pro L is not laminating and always says lam adjusting
Try Updating the firmware on the printer and the lamination module. Go to HIDglobal.com. Under the support tab, click drivers & downloads. Populate the drop down menus with make and model. The most recent software is shown here. Go to the section "Misc." and download Fargo Workbench. This utility enables you to update the printer by automatically pulling the most recent version off the Manufacturers website. Very Useful.
10/22/2014 8:07:33 PM • Fargo Pro L ID... • Answered on Oct 22, 2014
ALWAYS SAYING CARD JAM
blank cards not inserted properly - tray out of alignment
10/20/2013 4:12:45 PM • Fargo Pro L ID... • Answered on Oct 20, 2013
I need fargo pro L printer driver for windows 7
According to the Fargo Website:
http://fargosupport.com/archive_results.asp?archPrinter=5&archSubmit.x=42&archSubmit.y=5
The drivers only go as high as windows xp for now. Hopefully since Windows 7 is coming out soon that they will have a driver available for it shortly.
8/30/2013 10:01:46 PM • Fargo Pro L ID... • Answered on Aug 30, 2013
Every Other card is yellow
Head Problem need to replace.
1/2/2013 2:50:48 PM • Fargo Pro L ID... • Answered on Jan 02, 2013
4answers
Fargo Pro-L
The exe file gives you the driver, but there is no .exe autoinstaller.
You have to manually install the printer and load the driver using this path:
Settings -> printers -> add a printer -> add a local printer -> LPT1 port
once there ignore the drivers list and press "Have disk", then locate the previous unzipped driver location and press ok.
You should get your printer installed and ready.
Hope it was helpful.
8/23/2012 7:08:05 AM • Fargo Pro L ID... • Answered on Aug 23, 2012
4answers
Fargo Pro-L Not Printing Edge-To-Edge
These direct-to-card printers do not print right to the edge because of the way the print head comes down on the card. There will always be a white boarder on the card especially if your graphics are dense. The only solution to this issue is to re-design your artwork so that the image fades at the edges of the card so the white boarder is not obvious, or purchase a re-transfer printer which will give you true over the edge printing.
6/9/2012 9:12:26 PM • Fargo Pro L ID... • Answered on Jun 09, 2012
When I try to print it appears an error: flipper jam
Try to disable double sided printing in the Fargo settings?That should make the Filpper shut down,Selvol
3/6/2012 9:16:40 PM • Fargo Pro L ID... • Answered on Mar 06, 2012
I have an e machines computer with windows 7 home premium. It has an AMD Athlon II x2 235 e processor w/2.70 GHz. It has 6.0 GB RAM w/5.75 useable. And a 64-bit operating system. Is my computer powerf
As this is an older printer, the requirements are very low, a Pentium class 166mhz computer with 32mb of RAM is the minimum requirement.By manufacturers documentation, this printer is not supported by Windows 7. Its best if used with a Windows XP platform. -- The Pros at DiscountIDStore.com
2/11/2012 11:55:57 PM • Fargo Pro L ID... • Answered on Feb 11, 2012
Fargo Pro L ID Thermal Printer Logo
Popular Tags
63 questions posted
Top Fargo Office Equipment & Supplies Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Fargo Office Equipment & Supplies
Most Popular Question
installation manual fargo pro l printer
  • Office Equipment & Supplies
