Select something to print. Then go to FILE - PRINT and when the dialogue box appears, click to right of named printer on PROPERTIES. Then when that dialogue box appears, click on the MAINTENANCE tab and you can then click on Head Cleaning. Just make sure there is at least one sheet of A4 office-type paper in the printer, as when the clean has finished, you need to click on Nozzle Check. The printout will show if the nozzles are now working. Never do more than a couple of such cleans and always follow with the Nozzle Check printout - you can turn the paper round to use a fresh part - it only uses a small part of the paper each time.
