20 Most Recent Epson Stylus Photo R1800 InkJet Printer Questions & Answers
See status monitor? Is service required? Reset waste ink, Find resetter at indoreset.blogspot.com
Epson Stylus... | Answered on Nov 13, 2018
Get a Q-Tip and alcohol. Wet Q-tip with alcohol. Stand in front of the printer and look down where the paper feeds through. On the righthand side you will see a big roller that pulls the paper through and a little one right up under that. Clean both of them with the alcohol and Q-tip. Press the paper feed button and as it trys to act like it is feeding the paper, clean the roller with the Q-tip. Do this until the paper feeds through correctly.
Epson Stylus... | Answered on Jun 26, 2016
Select something to print. Then go to FILE - PRINT and when the dialogue box appears, click to right of named printer on PROPERTIES. Then when that dialogue box appears, click on the MAINTENANCE tab and you can then click on Head Cleaning. Just make sure there is at least one sheet of A4 office-type paper in the printer, as when the clean has finished, you need to click on Nozzle Check. The printout will show if the nozzles are now working. Never do more than a couple of such cleans and always follow with the Nozzle Check printout - you can turn the paper round to use a fresh part - it only uses a small part of the paper each time.
Epson Stylus... | Answered on Sep 18, 2015
User Guide:
https://files.support.epson.com/pdf/r1800_/r1800_ug.pdf
Looks like someone else answered it. https://www.fixya.com/support/t371048-remove_print_head_epson_stylus_photo
Epson Stylus... | Answered on Jul 22, 2015
Any more I just head to the big box stores and look for clearance printers, they come with print cartridges for 30-50 bucks new and I toss my old printer
Epson Stylus... | Answered on Apr 30, 2015
Epson Stylus Photo R1800 InkJet Printer Logo
393 questions posted
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Stylus Epson
  • Stylus Epson
Most Popular Question
took cartriges out unscrewed 3 screws
  • Office Equipment & Supplies
