Fargo Persona  C30 Thermal Card Printer Logo
A
Anonymous Posted on Jul 16, 2015
Is there a way to get in and lube the gears or something?
My card printer is squeaking like crazy while printing. Already followed the instructions to clean it - twice. Already replaced the printer cartridge. Already reset the printer, and reinstalled it. Already turned it off and back on, multiple times. This is rather frustrating, as I have about 800 ID's to make and nobody wants to put up with hearing this thing squeak and squeal for hours on end, least of all me. Is there some way to PLEASE make it stop?
Safe-Card ID Services
Level 2:
Novelist:
Scholar:
  • Expert 92 Answers
  • Posted on Aug 21, 2015
Expert
Level 2:
Novelist:
Scholar:
Answers
92
Questions
0
Helped
80971
Points
211
There are no lubrication points on these printers. They were discontinued many years ago, and are out of support by the manufacturer. It squeeks because it is old and worn, and the only permanent solution will be to replace it with a current model.
Sharp EL-1197PIII printing nonsense after a jam.
Reset the calculator: Locate the reset button on the bottom or in the battery compartment and press it .
Clean the printer head: Use a soft, dry cloth to clean the printer head and ensure that there is no debris or paper stuck in the printer mechanism .
you are looking for resources to properly align the gears. I found a few resources that might be helpful:
Sharp EL-1197PIII Operation Manual: This manual provides detailed instructions on how to operate and maintain your calculator, including how to align the gears. You can download the manual from the following link: SHARP EL-1197PIII OPERATION MANUAL Pdf Download ' ManualsLib.
Sharp EL-1197PIII User Manual: This manual also provides instructions on how to align the gears of your calculator. You can access the manual online from the following link: Sharp EL-1197PIII User Manual online (mans.io).
Sharp EL1197PIII Heavy Duty Color Printing Calculator User Manual: This manual provides instructions on how to align the gears of your calculator. You can download the manual from the following link: User Manual Sharp EL1197PIII Heavy Duty Color Printing Calc ' manualsFile.
1994 GMC Jimmy. I replaced the upper ball joints and the sway bar - for 2 days the car didnt squeak. Now it is louder than before. Whats next?
Did you lube the sway bar mounting pads? If these are urethane, they will squeak like crazy without silicone lube.
Phaser 7400 squeaks while printing
id try lubing the feed rollers well the metal bars where they contact the chassis and lube gears and stepper motors. its been awhile since ive had my phazer. i traded it last year to my church pastor but try that. radio shack sells a teflon lubricator part no. 64-2301a and im certain amazon also sells them. ONE drop goes a LONG way. its also a miracle worker for pc fans, and household appliances as well as automotive where its not high heat. even bearings.
hope this helps you a tad sorry i cant be more of a help here but thought id pass a few personal experience in fixing electronics/mechanical tips along.
Canon pc-921 squeaking noise
1- might be the scanning rail -- if you can open and lube LIGHTLY slide scanner back and forth ( w power off)
2- caould be Drum, some make a whistling/ hollow sound
Fear box squeaking noise
have a mechanic check gear lube in the transmission
When printing from paper tray, the printer squeaks and makes a noise that if anything else was doing the same noise you would think it needed oiling.
I would oil it. Printers need lube too. I would use graphite lube because it is thick and wont spread except from where you put it.
1helpful
I AM USING A BROTHER MFC 7340 SINCE 1 YEAR: NO PROBLEM EXCEPT WHEN PRINTING FROM PAPER TRAY, THE PRINTER SQUEAKS AND MAKES NOISE THAT IF ANYTHING ELSE WAS DOING THE SAME NOISE YOU WOULD THINK IT NEEDED...
The problem actually is probably due to needing lucubration. I would apply graphite lube to any rollers or gears in the user serviceable area. print 100 blank pages to make sure that the lube is spread thoroughly through the printer.
Good Luck!
2helpful
Squeaky printer/copier
Probably paper dust stuck in the gears, you can try to blow it out with some compressed air, it could be due to differing humidity levels now that it is getting colder - I wouldn't worry too much over it, some noise is normal. Clicking, grinding, popping, however - that could mean something is about to go. But slight squeaking shouldn't be too much cause for worry, there's alot of moving parts in there to keep well lubed up... ;)
1helpful
My printer is squeaking very loudly whenever it
Take it apart, and clean and lube the components.
Xerox xd125f
Most likely you need to replace the fuser assembly itself.
You can order it piece by piece, but you would have the cost of a heat roller, perssure roller, thermistor, gear and bushings. And that prices out more then a new fuser itself.
They can be purchased for the 200-230 dollar range.
If thats the route you want to take let me know. I can write out the instructions for replacement. It's not to hard to do.
Top Fargo Office Equipment & Supplies Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
