2002 Audi A4 Logo
Posted on Jul 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Abs light and traction control light
I have just replaced abs pump and got the pump reprogrammed. soon as i left Audi traction control light and abs light both come on?
Anonymous
Level 2:
  • Expert 101 Answers
  • Posted on Jul 31, 2009
Anonymous
Expert
Level 2:
Answers
101
Questions
Helped
69054
Points
226
My mates a6 had the same problem and it was the brake light fuse had blown.
Anonymous
Level 3:
  • Master 580 Answers
  • Posted on Jul 13, 2009
Anonymous
Master
Level 3:
Answers
580
Questions
0
Helped
317083
Points
1652
This may be result of faulty wheel sensor, as your traction control systems uses the ABS system to control power to wheels in the event of wheel spin
Anonymous
Level 2:
Scholar:
  • Expert 115 Answers
  • Posted on Jul 11, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
115
Questions
0
Helped
73354
Points
366
Hi ,
Take it back and tell them to code it properly! F.O.C.
Changed bearings and abs light and stabletrack still on do they reset after u replace the bearings and if so how long
Service Traction Control - Stabilitrak and ABS light, Help - Page ...
chevroletforum.com > ... > Tahoe & Suburban
Aug 16, 2012 - Service Traction Control - Service Stabilitrak and ABS light came on. ... Its supposed to still be under warranty, "Major Guard". ... I replaced my rear shocks with OEM re-manufactured Arnott shocks (great company) and in the ...
SilveradoSierra.com • Traction Control, Stabilitrak & ABS Issue
www.silveradosierra.com/.../traction-control-stabilitrak-abs-issue-t18976...
Jan 28, 2014 - Traction Control, Stabilitrak & ABS Issue. Tue Jan 28 ... The wife and I got in to head out and see my brother and as soon as I turned the key the ServiceTraction Control, Service Stabilitrak messages flashed and the ABS light came on. ... check your wheel bearings my was gone and caused the same thing ...
Chevrolet Impala Questions - Hello. I have a 2012 Chevy ...
www.cargurus.com > Questions > Chevrolet > Impala
CarGurusApr 6, 2013 - Occasionally when I hit the brakes I get a Stabilitrak Error Message " ... I believe GM still had 3 year/ 36,000 mile bumper to bumper ... After about 2 months of intermittent noises the ABS light came on, the service stabilitrak warning, servicetraction ... Edit....left hub bearing change after the right one changed.
Replaced front hub - now ABS/Stabilitrak lights on... - Chevy ...
2helpful
Traction control and abs warning light comes on,how do I fix??
the ABS system is defective, probably one or more of the sensors.
Traction control system works with the ABS sensors to monitor to monitor traction slippage.
Exclamation point in circle light on
Hi, Sounds like your abs braking system is at fault. The light would normally flicker when traction (tyres loosing grip with the road) is lost, Then as regained the light should go back out, however you have a sensor on each wheel either one of those may have packed in or your main ABS control unit under the bonnet may be at fault or on the way out. Also it may be your traction control switch that could be at fault. Hope this helps.
Abs, service engine light and trac off lights keep coming on
Hello. The ABS [anti-lock brake system], traction control and service engine soon light are all interconnected. The ABS and traction control each depend on sensitive sensors to send a signal to your car's computer that there is a problem. The problem unfortunately is that the sensors themselves are bad. If your brakes still pump themselves when you stop fast, for example, then your ABS system is still working but one of your sensors is sending a signal anyways.
To check everything out you can take your car to many auto parts stores, or most recently AAMCO transmission stores, where they will scan your computer for free. Once the scan is done you will know exactly why the service engine soon light is on.
In the meantime, you do not need to worry about your brakes because all the ABS system does is pump them for you. You can still pump them yourself, like folks did for years before ABS came along. Same is true with the traction control. As long as you do not drive wrecklessly you need not worry.
So to summarize, call around to auto parts stores, or AAMCO to get a free scan. Once you have those results you can decide on how to proceed.
Here is a great link if you want more information. http://www.aamco.com/Check_Engine_light_on-FREE_Check.asp
Regards, Joe PS kindly rate my answer. Thank you.
3helpful
The abs and the traction control light is on, how can i solve this problem
Hello. The Antilock Brake System [ABS] and tractioin control light are both connected to sensors near each tire. In many instances the systems work but one or more of the sensors goes bad. With the ABS system, you will know it is not working if the brakes do not pump themselves during a fast stop.
Begin by driving to an Auto Zone or similar auto parts store and have them put their scanner on your Audi. This will pinpoint the problems with your abs and your traction control. From there you will be able to decide on what course of action to take. Regards, Joe
1helpful
2000 liccoln ls (traction light)
i had a simular problem it was the abs sensor on one of the rear wheels 79.00 part.The wire plugs in under the seat and passes through the floor could be the connection also.
1helpful
5helpful
Traction conrtol , abs brake lights lincoln ls 2000
it might be a loose abs cable behind one of the brakes?
Abs light and traction control light cant figure out why?
clean ringer at wheel end..be sure you did not disturb alignment of sensor (VSS) which tells 'puter wheel speed for ABS and traction control
2helpful
2answers
Traction control light and abs light
ok your problem is that your brakes are under force you shold get new brake pads ok
Top Audi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you an Audi Expert? Answer questions, earn points and help others
