But showing paper size, not sensing paper. Already changed the tray, Pick up assy. also inter changed the tray switches. But still not sensing, why ?
SOURCE: canon ir 2016 digital copier
you can have 1 of 2 problems.
the cassete paper are in A4 position ,or you can trie to clean the registry roller.
SOURCE: in A4 and LGL the paper is fully loaded but it
first of all: when you put in paper cass. does the paper cass. produce abnormal sound like kling kling but without klang- if so the gear that rise paper is broken.( do not tray to remove and replace the gear without copy repair experience) this gear is in paper pick up unit, under the countless of clutches, spring, gears, solenoids,...
second: can you see if there is any sensor hanging, remove both cass. and try to compare!
If the machine copys normal from second cass. it is allmost 100% pick up unit.-call service
SOURCE: Canon IR 3300 model - Paper Load Liver problem in second tray
The tuck tuck sound is sound of paper pick up claw in pick up mechanism of second paper drower.The case is that the pick up clow is worn out and may be broken, so you need to replace it.To replace it you must remove complete pick up unit from the right side of copier, if you are not service technician do not do it by yourself it could be complicated if you do not know exact schedulle of parts and what does it doing.
SOURCE: canon ir 2016 is asking paper size, while paper in
It could be several errors.
1) do you have paper size senzor on paper tray set according the paper in?
2) It coud be that you have problem with paper pick up clutch
3) check the registration sensor flappers, door on the left of the tray flapper,...
4) try to clean the rollers
5) compare your paper lenght with some other paper manufactors
SOURCE: how to change papersize in
Open your drawer, you can see blue colored lever with arrow. Point that arrow to the size you want to use on your drawer.
