20 Most Recent Canon ImageRunner 3245 Black and White Copier Questions & Answers
my opinion Canon, lower service hours, better performanse, toner is onecomponent, so that means that you dont need to change developer...
On net find the technical specification and compare... the Canon is Canon!
Canon... | Answered on Aug 19, 2011
E024 The developing assembly connector is disconnected/Disconnection of Toner sensor.
u can do this steps : Disconnection of the wire used for detecting the connection of the
toner level sensor is found.
When the disconnection of the wire used for detecting the connection
of the toner level sensor has been detected for 7.5 min without
interruption (12.5 min in the manual /envelop cassette feeding).
of the toner level sensor has been detected for 12.5 min without
interruption
if it is problamatic you have to replace sensor.
Canon... | Answered on Apr 19, 2011
First, the streaks appears when copy from glass or adf, when printing or all?
Solution #1:
How many copies did you do from last drum changing? if over 80 000 copies, replace the drum unit.
-in case that streaks appears when copy and print
Solution #2:
If the streaks appears only if you copy from adf or glass, clean the glass and dry it out. Both glasses, narrow on left side beneath the adf/cover and glass for copy of original.
Solution #3:
If the streaks are wide and solid, with possible toner left overs, you need to replace fixing film.
Hope that helps!
Canon... | Answered on Apr 12, 2011
press a button with 123
Canon... | Answered on Jan 16, 2011
to be sure first check the paper size on cassette.Must match the paper size in cssette.Then under printer driver properties, check/set paper size matching one in the drawer.
Depending the program from wich you want to print also check when the printer dialoge is opened that you set correct sett. , like wich tray, wich paper size,...
Hope that helps!
Canon... | Answered on Aug 31, 2010
Code E806-0000
Fan Motor cannot rotate at specified revolution speed. When the same error repeatedly occurs after several times of turning the power OFF/ON, execute the following remedies :
Replace the Main Fan Unit
Replace the Engine Controller Board
Canon Office... | Answered on Dec 05, 2019
Code E001-0001
The sub thermistor detected an abnormally high temperature (295 deg C) during temperature control.
- Check the connector of the fixing film unit.
- Replace the fixing film unit.
- Replace the DC controller PCB.
Canon Office... | Answered on Dec 04, 2019
Hi. you need to enter in service mode
with the machine turned on, in the control panel do the next key secuence:
press adittional function
press 2
press 8
press again adittional function.
service mode should appear in the screen: (#SSW)
tap in the arrow ? or ? and search for CLEAR
press OK once, with arrows search for ENGINE and press Ok once, with arrows search for ERRCLR and press OK once more.
turn off the machine from the main switch for about a minute and restart it. try to make some copies, if problem persist there is a malfunction in the fixing unit, get technical support.
if this answer was helpfull , please rate it. thanks
Contact a local Canon service rep and find out what error code e000002-0000 indicates. This will determine what has to be done to get your printer up and running again.
Canon Office... | Answered on Dec 03, 2019
Canon ImageRunner 3245 Black and White Copier Logo
Popular Tags
21 questions posted
Clive
Clive
old marine
old marine
Ekse
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
copier buy canon 3245 or
  • Office Equipment & Supplies
