20 Most Recent
Canon iR 2016i Black and White Copier Questions & Answers
How to reset e808 error code
This error due to your red wire at fixing unit out of position,put back and switch on the macine and the error automatically cleared
RESET PASSWORD FOR CANON IR2016
My Canon C-IR2016 is demanding a Administrative ID & Password.I did entered the Admin PWD and latter removed it. but can't really tell what happen that after I restarted the copier, it still requested forthe Admin ID & Password. unfortunately the the details i used before is not functioning any more. PLEASE I need Help !! thanks
Pourquoi ma canon ir 2016 affiche modifier format papier tiroir 1 A4
bonjour j'avais le m?me probl?me avec mon iR2016. Mais j'ai un peu trouv? une solution. Lorsque vous voulez copier plusieurs pages je vous prie de bien vouloir retirer le bac A3/A4 et vous mettez les papiers dans le bac arri?re et d?marrer la copie vous n'aurez aucun bourrage ni Format Papier, ?a va marcher...
Canon ir2016 show
PROBLEM WITH CANON 1R 2016 PHOTOCOPIER
SHOWING ADJUSTING WAITING FOR SCAN
PLEASE HELP ME HOW TO FIX THIS
I have a canon ir2016
As far as I know, Canon IR2016 is stand-alone copier. Printing is optional using Network connectivity. The USB port found at the back is for upgrading purposes only.
Error code 002-0000 for canon ir 2202
Hi
A website I have found gives the details of this error for the IR2016 and the IR2022 as the same.
Description
Low temperature during temperature control.
The target temperature is not reached during temperature control.
Remedy
- Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the DC controller PCB.
Amongst other codes you can find it here:
Error Codes Canon iR2022
Hope this is helpful, if so would you please register that with Fixya
Cheers
