try a fact resest should be a pin set hole in the back take a pin/paperclip tooth pick Press & Hold for 10 sec that should reset rotuer to factory defaults. That may help if not unplug router from power & unplug wan ethernet or unscrew wan coax for 30 sec if that still dont work call your internet service provider they can do remote reboots that may help
There is usually a small hole on the back or bottom of the Belkin router that you insert a open paper clip into and gently push it in till the unit goes of and starts blinking. It will reset all the settings and passwords to factory defaults. Copy down any important settings you have made before doing the reset. Thanks for using FixYa
Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000 type *#06# on your phone to get it. hard reset *2767*3855# All Samsung Hard Reset Codes In those steps: 1.) *2767*3855# 2.) *7465625*638*00000000*00000000# 3.) #7465625*638*00000000#
If the unit acts erratically, reset the unit by inserting a thin object (such as a paper clip)
into the recessed Reset button. The Reset button is located near the headphone jack. It is a very small hole. This will resest you unit to factory defaults and will help determine whether its a software or hardware malfunction.
