HP DeskJet 5150 InkJet Printer Logo
A
Anonymous Posted on Jul 10, 2014
Printer printing slowly - HP DeskJet 5150 InkJet Printer
Remco
Level 2:
  • Expert 67 Answers
  • Posted on Feb 18, 2016
Remco
Expert
Level 2:
Answers
67
Questions
0
Helped
80546
Points
309
You may call on given 1-888-508-8524
Panasonic printer kx mb 262 driver download
Iakjanila, remove the toner cartridge slowly. 2. Tilt the cartridge back and forth to ensure even distribution. Do this slowly. 3. insert it again in the printer, close the compartment cover and now test print. GL
Printer prints slowly like "best
Go to Printer Properties and locate the Preferences then settings, and change the Quality there.
Bad print quality
frist keep your cartredge out after that beat top slowly slowly and then insert in your printer anter that restart your printer if problem is not solved then reinstalled your drivers of printer. after that problem is now here till then see your ink ribbon is on goog condition and the cartredge have ink and then restart the computer
17helpful
4answers
1helpful
2answers
I have a tally 2250 printer to beused under win98.
you can installed this printer driver of genric text only.
My 1800 is printing extremely slowly , until I
Your printer may have recieved a spike from the same lightning and fried the circuit board.
Is it under warranty?
If so call Epson and get an exchange unit.
The MAY help you if you mention the surge
Pixma MP 780 suddenly printing VERY slowly
Are you using Windows?
If so clean out your temporary files and defrag the drive.
Printers in Windows spool the job to a temporary file and then retrieves it.If the temp folder is full or the drive is fragmented this will cause your issue.
Printing slowly! Very slowly!
Well thats no good!
Remove the printer and reboot your machine.
Go back into the print queue and remove the printer,
Add the printer and try to print a test page.
- Vincent
1helpful
Specks on print out of Mono Laser Printer HL2040
If its spots this could have been from the cartridge or the fusser unit...
Do a half print test...send a print page to your printer listen to the printer print as soon as you think the printer has printed some little bit switch off the printer...take the cartridge and view the printed portion can you see the spots..if not.....than its your fusser unit thats marking the paper....remove the half printed paper slowly.....not to tear it......remover the fusser unit(hot unit)........at the back of the printer....towards the top....on the unit it self you will see a Teflon paper ....move the gear on the far end of the fusser unit itself and view if there is any spots....try cleaning this spots slowly as not to damage the Teflon or mark the Teflon.....
TSP700II prints V E R Y slowly...
I have a problem with some TSP700II printers that print extremly slowly. I have most recently downloaded and installed...
k24674
Grand Canyon Tech
Grand Canyon Tech
