20 Most Recent Samsung CLP 300 Laser Printer Questions & Answers
3answers
Samsung CLP-300 'dev. home error'
Dev. Home error can be fixed by stretching out a solenoid spring on the power cord side of the printer. The solenoid acts as a clutch to stop the spinning developer actuator at the right spot.
The problem is that the spring gets weak over time / the cogs round out over time and the solenoid finger is overcome by the spinning cogs, and resulting in selecting the wrong developer.
Open up the right side (power cord side) of the printer (take off top cover, then take off side cover). Then, find a solenoid (little metal square) that touches the white plastic vertical spur gear. Take the spring off the solenoid. Now, put the spring back on - only this time you will attach one anchor point to the middle of the spring as to pre-stretch the spring for more tension.
More pictures of the solenoid on Facebook:
http://www.facebook.com/#!/photo.php?pid=55779771&id=2257206&fbid=10100154259704133
5/25/2022 5:45:05 PM • Samsung CLP 300... • Answered on May 25, 2022
2answers
Samsung CLP-300 printer not printing,
2/3/2022 6:29:22 PM • Samsung CLP 300... • Answered on Feb 03, 2022
Paper feeding halfway through then stops
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
11/21/2021 7:07:04 PM • Samsung CLP 300... • Answered on Nov 21, 2021
My Samsung CLP-300 won't pick up paper (it goes 1 inch & stops)
No oil on rubber rollers! You must gently clean the rubber roller with isopropyl alcohol and a soft cloth. Let it dry and it should work again. Make sure to get ALL of the oil off of the paper paths surfaces.
11/15/2021 5:24:01 PM • Samsung CLP 300... • Answered on Nov 15, 2021
Samsung CLP-300 paper feed
Clean the feed roller.
Remove the paper tray, from the bottom there is a grey rubber semi wheel in the middle front of where the paper tray would be. Use a cloth with WD-40, brake cleaner, or lighter fluid to lightly wipe the rubber clean. Put the paper tray back in and it should print.
11/15/2021 5:23:35 PM • Samsung CLP 300... • Answered on Nov 15, 2021
Samsung CLP-300 Paper Feed Problem
I had same problem and it got resolved by lifting the front portion of the paper tray up. I put a spare USB drive under the paper tray for sufficient push upwards. It seems to be working fine now for me.
11/15/2021 6:03:41 AM • Samsung CLP 300... • Answered on Nov 15, 2021
Faded printing
Clean the toner roller bladesYou Tube Video http://www.youtube.com/watch?v=Ipw1RjwzUDgShows you the problem & how to fix it. There's a metal blade on the edge of each toner roller which can get clogged with small bits of toner & prevent even distribution. Clean the blade with a lolly stick & put it back together.I tried this with CLP 320 cartridge - same principle but can be messy because the cartridge is full of toner powder.
11/15/2021 6:01:23 AM • Samsung CLP 300... • Answered on Nov 15, 2021
I emptied the waste toner
Sometimes just emptying the waste toner tank will not clear this fault. The printer uses a light sensor to determine when the tank is full. You will need a cotton swab and clean the part of the tank that the sensor is viewing the tank. Try to clean the clear window of the inside of the tank. It can be difficult since the placement of the window with respect to the tank opening. Other way is to try to wash out the inside of the tank with soap and water which can be messy but it will do a better job. Hope this helps.
10/7/2021 3:14:10 PM • Samsung CLP 300... • Answered on Oct 07, 2021
3answers
Spl-c error-including corrupted data BEWARE SPAM NUMBER +1-800-532-4187 BELOW
I should have updated this a while ago, as I see others have had the same problem since my post on 27 August.
After calling Samsung technician out to take a look, he suggested getting a higher quality cable (conected to the computer). Despite the fact that the cable which we'd been using for months always seemed to work ok, we got another one of higher quality, and the printer now works fine.
I don't know why the cable stopped working efficiently, but it did.
I hope this helps...
2/9/2021 1:22:39 PM • Samsung CLP 300... • Answered on Feb 09, 2021
5answers
I have a Samsung that say Transfer Belt Error
Hi
I have a utility to reset the consumables errors on this printer, but only if the component is past its lifecount. (60k for transfer belt)
Its called CLP-300_Reset_RLCv04.exe or just RLCV-04.exe (if you can find a copy)
If you need a copy, let me know and I'll find some way to get it to you.
I've used it for transfer belt reset and it works.
1/23/2021 1:20:57 PM • Samsung CLP 300... • Answered on Jan 23, 2021
3answers
Samsung Printer Setup & Support Call 1-8O5-225-669O We are 24 Hour Available Call For Help... Phone Number
make sure that when you go to print under propertys choose color tab and then color
11/26/2019 1:14:36 AM • Samsung CLP 300... • Answered on Nov 26, 2019
2answers
Samsung printer
go to samsung website,under support and downloads,type clp300,will get drivers
11/12/2019 3:04:11 AM • Samsung CLP 300... • Answered on Nov 12, 2019
2answers
MY SAMSUNG PRINTER CLP300 IS
9/30/2019 9:00:13 PM • Samsung CLP 300... • Answered on Sep 30, 2019
RED status light in Samsung CPL 300N
try downloading the manual from here.
http://www.samsung.com/uk/function/search/espsearchResult.do?keywords=CPL+300N+&input_keyword=CPL+300N+
9/10/2019 4:27:27 AM • Samsung CLP 300... • Answered on Sep 10, 2019
Samsung CLP-300 printer, very poor black coverage
Samsung printers are far from the best. I have the same printer and it needs a Fuser. The fuser part costs more than I paid for the printer and it's a little over a year old. Samsung will not sell me the part but will repair the printer for $135 plus the part which costs over $135. Shipping is $20. I only paid $141 for the printer. I'll stick with Epson and to hell with Samsung.
9/9/2019 1:30:59 AM • Samsung CLP 300... • Answered on Sep 09, 2019
I have samsung printer 1600. The printer not pick
http://support-us.samsung.com/cyber/popup/pop_troubleshooting.jsp?ia_cd=06010200&model_name=CLP-300
The above is for the clp-300 laser printer.
You say you have a samsung print 1600 but when I searched I found a blue ray player with that number.
Is this the right link?
7/11/2019 2:54:15 AM • Samsung CLP 300... • Answered on Jul 11, 2019
Samsung CLP-300 shows red light . what does it
Dear ,
Install a smart pane software from samsung.com and search clp-300 printer and download the software.
3/5/2019 3:34:50 AM • Samsung CLP 300... • Answered on Mar 05, 2019
LSU Motor Error Cycle Power
i have problem with samsung laser printer ml 3470 series, lsu motor error
11/21/2018 2:33:14 PM • Samsung CLP 300... • Answered on Nov 21, 2018
Samsung CLP 300 Laser Printer Logo
1,096 questions posted
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
CLP Samsung
  • CLP Samsung
Most Popular Question
samsung clp 300 printer very poor black
  • Office Equipment & Supplies
