Canon DR-9080C Path-Through Scanner Logo
A
Anonymous Posted on May 29, 2014
When scanning a Document my image is black but the writing is white how do I get the back ground white and the words black
I have it set on black an white
5 Related Answers
Anonymous
  • 883 Answers
  • Posted on Jun 01, 2007
SOURCE: After i scan a document, the image appear in black screen. Why?
uninstall the software from pc and turn off. then restart and re-install software.
Anonymous
  • 4889 Answers
  • Posted on Oct 08, 2007
SOURCE: scanner started scanning color photographs in black and white
The problem is simple.Someone or somehow the "TYPE OF ORIGINAL" option on ur SCANGEAR CS window.Set it back to "MAGAZINE" or "PHOTO" and it should scan in color.
Anonymous
  • 111 Answers
  • Posted on Oct 29, 2008
SOURCE: scan and make changes to document later
You need to use OCR. Use the OmniPage Se application that shipped with your scanner.
Anonymous
  • 111 Answers
SOURCE: Canoscan 8400F problem
If possible, try it on another computer. If the symptom is the same, then the scanner requires service.
Anonymous
  • 45 Answers
  • Posted on Jul 06, 2010
SOURCE: When I go to scan a document, I am asked to link
instead of scanning directly through scanner, you should go first to the application like word/pdf writer or pagemaker etc and then import it from within the application using file<import (option can vary application to application).
How do I scan multiple documents and email them as one attachment
1. Click PDF on the Custom Scan with One-click tab or click PDF in the one-click mode screen to open the PDF dialog box.
* If you wish to convert the text in a document to editable text data, scan the item with the OCR. The precision of OCR is affected by the nature of the scanned original
2. Select the type of document to be scanned.
Important
To scan correctly, select a document type that matches the document to be scanned.
3. Select a file type to save the scanned image.
Select PDF, PDF(Multiple Pages) or PDF(Add Page)
Important
Click Set... to open a dialog box and specify the PDF compression type and other advanced settings for creating PDF files.
4. Place the first original on the scanner and click the [Scan] button at the right bottom corner of the PDF window.
5. When scanning is completed, place the next original and click the [Scan] button.
6. Repeat scanning by clicking the [Scan] button until you finish all the originals.
7. When all the original is finished, click the [Exit] button.
8. When the scan is complete, it automatically starts the application program that displays PDF files and opens the scanned image file in it.
To scan a text document or black and white document, you are recommended to set the Scan Mode to Black and White or Grayscale.
You are recommended to limit the number of pages in any one multiple PDF file to 20 or less if you are scanning a color document with the Image Quality set to 300 dpi and the size to a setting equivalent to Letter size.
How to have white background on small documents
All areas outside of the document will be black only. I don't know how you were getting white background.
If you want white background around your scanned image, a) stick the check (in this example) onto a white paper and scan the whole sheet. Ensure double detection is off. b) You can also do this in software, by cropping a larger area outside the scanned image.
There are many options to view the scanned image like Actual size or Fit or Fit vertically or Fit width. The same image will appear different in each case.
S. Mohan, India
Want to print black and white. How?
Setting the font type color in a Microsoft Office Word document to black will ensure that the document prints the text in black. However, if there are images, graphics or photographs within the document, they will more than likely print in color or hued colors similar to black. To ensure that the entire document prints solely in black ink, you must set the color settings on your individual printer to black-and-white
Instructions:
1.Click "File" and then "Print." To open the print dialogue box using keyboard commands, press "CTRL" and "P" simultaneously.
2.Select the printer you are using at the top of the dialogue box under "Printer" and "Name."
3.Click the "Properties" button next to the selected printer. The dialogue box that appears is different for all users, as it depends on the type of printer being used.
4.Click on a tab, button or selection box indicating "Color." Most options include high-quality color, grayscale and black cartridge only. Choosing grayscale will print the document using various shades of gray and other tones such as blue or green that match the actual hues in the document visible on the screen. A photo or picture that may look black or gray could actually have blue undertones. To print purely in black and white with no undertones, you must select either "black cartridge" or "black and white only."
5.Select "OK" to return to the Microsoft Word printer dialogue box. Press the "Print" button to print the black-and-white document.
I hope you find it very helpful. Thanks.
How do you scan?
Open the Applications folder on the hard disk on which MP Navigator is installed, then open the Canon Utilities folder and double-click the navicon.gif MP Navigator 3.0 icon. MP Navigator opens.
2. Point to Scan/Import and click 'Photos/Documents (Platen)'.
3. Place the document face-down on the platen glass, and select 'Document Type'.
How to place the document and Document Type depends on the document to be scanned.
Allow 3/8 inches (1 cm) or more space between the edges of the platen glass and the document.
Align a corner of the document with the corner at the arrow of the platen.
  • When you select Color Photo or Black and White Photo, the position or size of the image may not be scanned correctly if you do not leave 3/8 inches (1 cm) or more space between the edges of the platen glass and the document.
  • When you select Color Photo or Black and White Photo, the position or size of the image may not be scanned correctly depending on the document. In such a case, select Document Size such as A4 or Letter according to the document to be scanned.
  • When you select Magazine(Color), the Descreen function will be enabled and scanning takes longer than usual. To reset the Descreen function, disable Descreen in the Scan Settings dialog box.
4. Click 'Specify'... and set the preferences as required.
The Scan Settings Dialog Box opens. Specify the Document Size and Scanning Resolution.
  • When Document Size is Auto Detect or Auto Detect(Multiple Documents), the position or size of the image may not be scanned correctly depending on the document. In such a case, select Document Size, such as A4 or Letter according to the document to be scanned.
5. Click 'Scan'.
Scanning will begin.
When the document has been scanned, the scanned image is displayed in the Thumbnail List area.
I am trying to scan a document and it is not working, I have a hp photosmart c4280 printer. How do I install a usb cord
hi
Place the document or image into the scanner for scanning. A scanner with a paper feeder will only receive flat papers and photographs, but a flatbed scanner opens to accommodate books, fabrics and leaves along with flat papers. There is even a attachment for feeding photo slides into flatbed scanners.
  • Step 2 Start the scanning softwaremag-glass_10x10.gif. If the scanner does not engage the software automatically, press the "start" or "scan" button, or click the scanner icon on the computer screen to initialize the software.
  • Step 3 Activate the scan. Click the "file" menu and select "acquire," "import," or another practical choice that applies.
  • Step 4 Preview the item to be scanned. Most scanners have a preview option. This will show the scan area inside dotted lines. The lines can be moved with the mouse to relocate, enlarge or crop the scanning area.
  • Step 5 Set the resolution for images by number of dots per inch (dpi). For computer screen viewing, 100 dpi should suffice. Use 200 to 300 dpi for items to be printed.
  • Step 6 Use the appropriate setting for scanning black and white text. If the scanner does not show a preset for text, use "line art" or "black and white" at 300 dpi. Then use the optical character recognition (OCR) program to convert the image of the text into a file for word processi
  • 5helpful
    Scan multiple pages to email
    Do you have Microsoft Office?? If you do try this:
    First, gather the paper you want to scan. If your scanner has anADF, you can load a stack of pages at a time. The first time you scan,Document Imaging detects the ADF for you.For more information about the ADF and whether your scanner has one,see the documentation that came with your scanner.
    You will also want to sort your paper; if you have color pages thatyou want scanned in color, sort these in a separate stack from theblack and white pages. Load your first page, or first stack of pages(with an ADF) in your scanner.
    Then, start Microsoft Office Document Scanning (the scanning component of the Microsoft Office Document Imaging program.)
    • On the Windows Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Scanning.
    Tip If Microsoft Office Document Imaging is already running, you can start the scanning component by clicking Scan New Document on the File menu.
    Set up your scanning optionsIn the Scan New Document dialog box, do one or more of the following:
    • To view your scanned file(s) in Document Imaging after they have been scanned (recommended), select the View file after scanning check box.
    • If your scanner is equipped with an ADF, click Scanner, and then select the Use automatic document feeder check box.
    • If your scanner is equipped with an ADF and you have double-sided originals, select the Original is double sidedcheck box to scan both the front and back of multiple pages. Place thepages in the feeder so that the page fronts are scanned first.The Microsoft Office Document Scanningdialog box will appear after each scan, allowing you to turn the pagesover and scan the page backs. Document Imaging automatically collatesthe pages in the correct order after scanning is complete.
    • If you have a true duplex ADF (one that automatically scans both sides of the page), do not select the Original is double sided check box. Instead, in the Scan New Document dialog box, click Scanner, and then select the Show scanner driver dialog before scanning check box. When your scanner driver dialog box appears during scanning, select the proper duplex settings.
    • If you want to scan pages manually, select the Prompt for additional pages check box. Office Document Imaging will pause after each page is scanned, allowing you to place the next page in your scanner.
    • By default, optical character recognition (OCR) is performed onyour document during the scanning process. Although performing OCR addstime to the scanning process, it also has the following benefits:
      • When you open the scanned document in Microsoft Office DocumentImaging, you can search for recognized text in the document, copyrecognized text in the document to another document or program, andsend recognized text in the document to Microsoft Word, withoutperforming OCR manually.
      • You can have your scanned files saved with an automatic filename based on the first words on the page (this is the default.)
      To turn off OCR during the scanning process (you can perform OCRmanually in the document in Document Imaging after scanning), do thefollowing:
      1. In the Scan New Document dialog box, select the preset you want to use, such as Black and white.
      2. Click Preset options, and then click either Create new preset (and then type a name for the preset), or click Edit selected preset.
      3. On the Processing tab in the Preset Options dialog box, clear the Use OCR to recognize the text of the scanned image check box.
    Select location, name, or file type for the scanned filesPart of the scanning process is to save a scanned page to a file. Bydefault, when you scan multiple pages, the pages are saved in one file.If you want to save each scanned page as a separate file, select thenaming convention for the scanned files, or change the location or fileformat of the scanned files, do any of the following:
    3. Do one or more of the following:
      • To save each scanned page as a separate file, select the Save each page as a separate document check box on the Page tab.
      • To change the location for the saved files, click the Change button on the Output tab, and select a location.
      • To select the way the individual files will be automatically named, click one of the File Name options on the Output tab. (If you have turned off OCR during scanning, you will be unable to use the Auto name based on first words on page option.)
      • To select the file format the scanned pages will be saved in, click the Advanced button on the General tab, and select the options you want.
    4. Click OK.
    Scan your pages
    1. In the Scan New Document dialog box, make sure the preset you want to use is selected, and then click Scan. If you selected the Original is double sided check box or the Prompt for additional pages check box, the Microsoft Office Document Scanningdialog box appears periodically to let you know that the scanner hasfinished. You then have the option to continue scanning (place anotherpage in a scanner that doesn't have an ADF) or turn your page or pagesover to scan the other side. Arrange your page or pages as desired, andselect the option you want to continue scanning.
    2. When all pages, all sides have been scanned, click Done in the Microsoft Office Document Scanning dialog box.
    3. To scan additional pages, review the Get started section above, and then repeat the instructions in this section (Scan your pages.)
    Organize pages in the saved file(s)Now that you've finished scanning, it's time to take a look at theresults. If your scanned pages are not open in Document Imaging, do thefollowing:
    1. On the Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Imaging to start Document Imaging.
    2. In Document Imaging, click Open on the File menu.
    3. Locate the file you want to open (by default, the scanned page(s)is saved to the My Documents folder with an auto filename based on thefirst words on the page, such as Page1of.tif) and then click Open.
    4. Repeat steps 2-3 until all of the files you need are open.
    You now have an online version of your stack of paper. Here are a few tips to get you started organizing pages.
    • Rearrange pages within a document In the thumbnail pane (thumbnail pane: Presents the current scanned document as one or more small images.), select one or more pages to move. Click any selected thumbnail and drag the selection to the new location in the thumbnail pane.
    • Copy a page to a new document In the thumbnail pane, select the page you want to copy. On the Page menu, click Copy Page. Switch to the Document Imaging document into which you want to insert the copied page. In the thumbnail pane, select the page that precedes the location where you want to paste the copied page. On the Page menu, click Paste Page.
    • Delete a page In the page pane or the thumbnail pane, click the page you want to delete. On the Page menu, click Delete Page.
    For more information about scanning or organizing pages, see Microsoft Office Document Imaging Help.
    The papers that were once cluttering your desk have now beentransformed into electronic documents. Within these documents, you canarrange pages, move pages to different documents, delete pages, printpages, add annotations, copy text to other Office programs, or send apage to someone in email. And still have room on your desk for yourcoffee.
    Images scan black via flatbed or auto feed
    Check your software settings, Try Auto Brightness for scanning a white sheet.
    S. Mohan
    We have a canon MP610 printer scanner combo, I work in a dentist office and am trying to scan a x-ray. When I do it is'nt picking up the detail very well at all. I think I need to adjust the settings but I...
    the only way to get a little more detail out of this printer with x-rays is to INCREASE the DPI resolution. there are no other adjustments that are abailable.
    The Scan Settings dialog box opens when you click Specify... on the Scan/Import Documents or images screen.
    The Scan Settings dialog box allows you to specify advanced settings for scanning.
    Document Type
    Select the type of document to be scanned. To scan photographs, select either Color Photo or Black and White Photo. To scan text documents, select either Color Document, Black and White Document, or Text(OCR). To scan magazines, select Magazine(Color).
    Document Size
    Select the size of document to be scanned.
    Auto Detect: Detects document size automatically.
    Auto Detect(Multiple Documents): Select this when scanning multiple documents at one time.
    Select Stitch-assist to scan the left and right halves of a document separately and combine them back into one image.
    Reference See the section below for details.
    Scanning images Larger than the Platen (Stitch Assist)
    When you select Custom, a dialog box in which you can specify the document size opens. Select a Unit, then enter the Width and Height and click OK.
    Important When you select Auto Detect the position or size of the image may not be scanned correctly depending on the document. In such a case, specify the document size, such as A4 or Letter according to the document to be scanned, and align a corner of the document with the corner at the arrow of the platen.
    When you select Auto Detect(Multiple Documents) allow 3/8 inches (1 cm) or more space between the edges of the platen and the document.
    If not, some images may not be scanned at the correct positions and sizes.
    You cannot select Auto Detect(Multiple Documents) or Auto Detect when Document Type is Text(OCR).
    Scanning Resolution<<<<-------------------------------------------------------------<<<<<<<<<<
    Select the resolution at which to scan documents. The following scanning resolution can be specified:
    Text(OCR): 300dpi, 400dpi
    Others: 75dpi, 100dpi, 150dpi, 200dpi, 300dpi, 400dpi, 600dpi
    The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail. At high resolution, scanning takes longer and file size becomes larger than usual. See the section below for details on resolution.
    this should answer your question , feel free to post here agian if you need more help.
    Regards, and thank you for using fixya.
    Scanned image only prints in black and white
    it's tricky / annoying:
    you have a preview ...
    you have some of the (3) images checked
    but also you have some of these images selected (blue outline)
    now:
    when you select (I don't mean the checking) an image you'll have to set the scanning params
    again - or check them ...
    if you select an image, and then set the params (like "color"), your scanned image will be in color
    also resolution is the same way ..
    especially after crating preview .. it'll be set to 300 Dpi
    so after seecting one for scanning - check the resolution too :)
    jepe
    2answers
    Scanning
    Did you tried with any OCR software to convert the Scanned imaged (jpeg) to Word Documen?.Always if you scan anything to an image, it will scan in JPEG format that will consume lot of memory.Scan with OCR(Optical Character Recognition) Software and that will Convert JPEG to word Document which will fix the problem.
    The OCR software that i Recommend is ABBY Fine Reader.
    Thanks
    Riz
    old marine
    old marine
    ZJ Limited
    ZJ Limited
