Brother HL3040CN Laser Printer Logo
A
Anonymous Posted on Apr 03, 2014
Hl3040cn printer with streaky printing - Brother HL3040CN Laser Printer
I have a brother hl3040cn printer.I print property brochures and they are very dark.They were ok.any ideas
I would first check to see if you are using New / O.E.M. Toner and drums. Most compatible / remanufactured Toner and Drums work okay , they don't do well on Brochures or rich Graphic prints. If you hav'nt installed any supplies recently, the Drum Units is where I would start. Not usually a Cleaning issue.
Brother printer printing large
Please Click menu button and then click ok 3 times
if the test print is same size ??? then click factory reset option
Streaky printing
I have replaced the color and black cartridge . I have cleaned it and it is still streaky printing. What do I do?
29helpful
Brother hl3040cn. I have replaced black cartridge it now says other 3 need replacing. Was printing ok before black ran out; not printed colour for long time. thanks
This printer tells you to replace the toner when there is still plenty left. You can override this as follows:-
1. Open the top cover
2. Press "Secure print" and "Cancel" together
3. This brings up the cartridge menu. Press "OK" twice for each entry, then scroll down to the next one. There are two entries for each colour, dunno why.
4. When you've done all 8 entries shut the lid and print.
This may need to be redone every few months.
The printed pages are coming out really streaky. We have tried cleaning it, but no joy. Any advice?
Print a few pages. As they are printing open the cover. Remove the toner cartridge. Look down at the page that was being printed. If it is not "streaky" look at the fuser, it probably needs replacing.
If that page is "streaky" replace the toner cartridge.
1helpful
Okidata C5200N printer: streaky copies on magenta
If the streaks are only from the magenta then your magenta drum is bad. If you recently replaced it, it may still be under warranty.
C5150: All color prints are extremely streaky and
This happened to me. It was caused by a bad "oki compatable" color cartridge. One time it ruined my drum. It was always the yellow color. Decide which cartridge is printing streaky. Remove it, bang it on the inside of a large plastic garbage can. Clean it. Reinstall it . If it still prints streaky throw it befor you ruin the drum. Replace it.
Replaced Cartridges and now all printing is streaky
Try removing the printhead (to remove it just follow the instruction on this website www.kodak.com/go/printheadsupport
if removing the printhead did not fix the problem the printhead might be in need of replacement you either go to this website www.kodak.com/go/stepbystep or call 1800 421 6699 for your printhead to be replaced
Streaky printing
At most cases of printer, especially which have done refill at cartridge, print quality is poor or streaky. Many factors influencing this printed result. To overcome print quality is poor, maybe following tips can usefull to prevent printed pages are missing lines or streaky.
First step is ordinary to be done many people when print quality is streaky that is doing cleaning. To get good printed result, sometime this facility is used more than once.
Use Ink Refill with Quality Nicely
For printer have refilled, sometime the quality of printing is also influenced by ink. If will fill your printer again, use ink which the was quality of nicely. I have tested some refill inks at cartridge which have been ascertained still nicely ( sorry: I do not want to publicize result of this attempt). In the reality result make me surprise, there ink of refill making the printed quality is crummy. To choose ink refill read following tips :
  • See viscosity of ink, every merk of ink refill have difference of viscosity. Don’t use Ink refill too jell. Difference of this viscosity is no measure reference viscosity of ink from factory maker of printer
  • Don’t fear to try some inking merks. Done this, you’d find refill ink fitt with your printer. I now only using one merk of refill ink ?.
  • This suggestion of forum, but I still not yet proved. May believe or not. Good ink aroma of soft usually.
Change Original Cartridge
This is last choice. A lot not like to do this ways, because price of original cartridge still costly. Alternative, you can use compatible cartridge which the was price of cheaper than original cartridge. At newest printer, usually there are two until four cartridge in one printer. And price four same cartridge almost at the price of printer even there are some costlier.
Let me know !
Thanks
Fame !
Norman Weimar
Norman Weimar
k24674
