20 Most Recent
Canon PIXMA MP130 All-In-One InkJet Printer Questions & Answers
Check Printer (5B00)
try this -
1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan
2) Enter NVRAM by presing <--- or ---> then OK
3) SET ABS-M LEVEL TO 0
4) OK
good luck
The waste ink absorber is
There are two
possible ways to remove the error from your printer. First is to actually clean
the absorber pads that are full of waste ink. The second is to reset the
printer to clear the error and let the printer print again.
Clean the two absorber pads. Its
is actually two absorber pads located on the right side of the printer, under
the ink cartridges when it is in home base position.
How to access the
pads and remove it for cleaning?
Turn on the printer. Lift the top cover to
expose the ink cartridges. As soon as you lift up the cover the cartridge
carrier will move away from its home base.. Then the pads will be exposed. It
will be a dirty job so be prepared with your tweezer and extra cloth for some
ink spill. Using the tweezer, lift up the pads sitting on a rubber retainer.
The pads can be easily clean by placing it under a running water. Warm water
will be nice to remove the ink from the pads. After this, you can now return
the pads. However, the problem will not be solve especially if you are
currently facing the waste ink absorber full error or E-27.
Use a reset procedure to clear the error in your
printer
and start printing again
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
1. Turn
on the printer
2. Press
the MENU key
3. Press
SCAN button
4. Press
the COPY button
5. Press
the SCAN button then wait until it enters the service mode.
6. Select
NVRAM ACCESS further OK
7. Select SET ABS-M LEVEL and set value equal to
zero
8.
Select SET ABS-R LEVEL (if any) and is set to
zero.
9. Turn off the printer
Normal
0
font-size:10.0pt;
Do this as many times if the first attempt
didn't work until it fully reset.
Pixma mp130 printer
The check ink tank is an error message based on either:
1.) How many pages have been printed
2.) How many times you have replaced ink tanks
3.) How many hours the Printer has been on.
Most of us understand this is based on a page print counter.
There is usually a method to turn this off using a manufacturer's method taht's leaked out to the tech community. There are a few Canon tricks and I'll post one to you later that may or may not help.
I do want to assist you first and foremost on the payment you believe you were charged by the receipt being issued. This may have been a glitch as this does happen but you need first peace of mind on the billing and then support. As you have posted this 'help ticket' into the Free Forum, I'll also see if we can reset your Canon too.
Can you give me the date on the receipt and an invoice number first?
Thanks,
Worldvet
Cartridge Jam
try to put out the cartridge casste and put it back then clean the nozzles
Error u162?
Press and Hold the
STOP/RESET button and wait until it self restart.
Release the
STOP/RESET button when the printer is restarting
Canon pixma MP 130/110 printer - error code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
HOW CAN I REMOVE THE PRINT HEAD ASSEMBLY ON A CANON MX340?
Follow the given steps:1. Confirm that the printer is powered on.2. Open the paper output tray and top cover.Note: Gently open the paper output tray while holding it.3. After confirming that the print head holder has moved to the center, open the inner cover.4. Remove all ink tanks.5. Raise the print head lock lever and remove the print head.6. Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.7. Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.8. Close the inner cover and top cover.If you need any technical help on printer then you can reach at
http://www.vtechsquad.com/
