INK SYSTEM FAILURE HP 0XC18A0101
Ink System Failure refers to a hardware issue with the printer, however a series of troubleshooting can be tried as a last resort before you get a replacement of your printer.
Try the following:
1. Press and hold the “*” key and then press the “#” key and release both keys.
Now check if there is any message on the printer display,
it should display something like "Enter Special Key Combo"
2. Now press and release in sequence the “1”, “2” and “3” buttons.
it should display something like "Support"
3. Press and release the right arrow button until the display says “System Configuration Menu”.
4.Press and release the “OK” button.
Now the display should say “Hardware failure status”. If not there already, scroll the arrow Key over to “Hardware failure status”,
5.Press and release the “OK” button.
Now the display should say “Hardware failure status: Clear. Press OK to clear”.
6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
7. Now Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Turn the printer OFF using the power button and unplug the power cable from back of the printer and wall outlet.
9. Wait for 30 seconds and then replug the power cable
10. Turn ON the printer and let it initialize itself.
Then try printing a self test from the printer front panel by pressing the SETUP-->Print Report--->Self Test Report.
This should get it working again.
