SOURCE: battery and or charger
Hi you have mentioned
"Sometimes if I jiggle the AC adapter connection to the laptop when the
battery icon starts flashing I can get it to continue working."
Looks like you have a lose jack on your notebook or the adapter itself....try to shake the connections when fitted to the notebook and check weather its the adapter or the note book jack....
If you dont have experience opening your notebook and soldering or soldering your adaptor end i suggest you take it to repair center
keep me posted
Cheers!
SOURCE: My 3200 will only run when plugged into charger, won't charge bat
Try dusting the connector pins on your laptop and connecting the battery back.
SOURCE: laptop keeps shuting down at random.
This could be caused by MANY different things. If it is a random thing, where do you have your laptop when it happens? If it isn't on a flat smooth surface, it's probably a heat related issue. Laptops need a lot of air circulaton, through the bottom.
SOURCE: when my acer aspire 5734z
It is a sign that your battery is failing. Try to remove the battery then put it back. After that, try to check if you still experience the same thing. If so, then you need a new battery replacement.
Batteries usually start to degrade after a year or after 500 charges, whichever comes first.
SOURCE: hi i have a samsung r519 and i carnt figure out
check originality of the P.S.U.--check it is the correct item running at the stated values.Check the polarity of your connection,this is printed on the side of some units its like a small ball surrounded by a "C" check you dont have one of those universal P.S.U's which have connectors that have to be correctly connected --look for a small "arrow" on the side of the connection denoting correctly plugged in.
