20 Most Recent HP Compaq nc6000 Notebook Questions & Answers
Pl switch the machine off and put 2-3 pounds of pressure with your palm on the keyboard closer to the spacebar.. this will fix it..
it is caused by the weakening of the adhesive of the wires below the keyboard.
Long term option - get the keyboard opened by the an professional and cleaned properly..and fixed back neatly...
HP Compaq nc6000... | Answered on Sep 27, 2017
do you have a 2nd laptop,if yes pls do a speed test.
if this works then you need drivers reinstalled
HP Compaq nc6000... | Answered on Sep 26, 2017
You can download the video and device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
www.compaq.com/country/cpq_support.html
HP Compaq nc6000... | Answered on Jan 09, 2017
Solution 1 - Reset TCP/IP stack
To reset your TCP/IP stack, do the following:
  1. Right-click on the Start Menu button and open Command Prompt (Admin)
  2. Type the following command and press Enter: netsh int ip reset
  3. Reboot your PC and check if you're able to connect to WiFi network. If you can, you're good to go, but if not, type the following commands in the elevated Command Prompt and press Enter after each one:
  • netsh int tcp set heuristics disabled
  • netsh int tcp set global autotuninglevel=disabled
  • netsh int tcp set global rss=enabled
  • ipconfig /flushdns
Solution 2 - Re-configure WiFi Adapter
Maybe reconfiguring your WiFI adapter will solve the problem. To do so, follow next steps:
  1. Go to Search, type device manager and open Device Manager
  2. Right-click on your wireless adapter and go to Properties
  3. Go to Power Management tab, uncheck Allow the computer to turn off this device to save power and click OK
  4. Modify the default power plan, and switch it from high energy savings to low
HP Compaq nc6000... | Answered on Jul 14, 2016
Shafi:
Boot the computer while holding the F-7 key to get into the bios setup.
HP Compaq nc6000... | Answered on Jun 16, 2015
1,check power supply.
2,check battery.
3,check the fan is trying to run.if its not it may need cleaning.
4,over heating can stop it from starting.
HP Compaq nc6000... | Answered on Apr 14, 2015
Turn the computer off in the normal way.
Turn the computer on, tapping the F2 key [it might not be F2, could be esc, F1 F8 or F10, depends on the make and specific model of your PC, for my HP desktops it's F2] a few times each second. This should enable you to enter the BIOS set-up (which key to press) (see https://answers.yahoo.com/question/index;_ylt=A0LEV2bavtZTVmcAjVFLBQx.;_ylu=X3oDMTE0bTVyc3Q3BHNlYwNzcgRwb3MDMQRjb2xvA2JmMQR2dGlkA1ZJUFVLMDdfMQ--?qid=20071012195523AAXHNK3)
Look at he screen carefully while you do this, because the computer often tells you how to enter the BIOS setup during the start-up process, but the information isn't the for very long: you may have noticed this while you starting the computer all those times in the past.
Once in the BIOS set-up navigate to BOOT options or something like that. You may have to work your way every option (there aren't that many) to find it. Once there it will show a list of places to boot from - these are typically the hard drive, the optical disk drive, and the USB port, you may even have eSATA option. These will be in order. Change the order to make the laptop try to boot from a USB device first. Now exit the BIOS set-up saving the change to the boot device order. If there isn't a USB device when you next boot the laptop will just try the second device on the list. If you start up the computer with a bootable USB device in a USB port, it will boot from that device. (eg a flash memory drive)
There are other ways, but this is fundamental way if your BIOS supports boot from USB (my desk tops do not so I had to find another way)
28.July.2014
HP Compaq nc6000... | Answered on Jul 30, 2014
Press F8 when the Compaq logo screen appears and enter the bios. From there you should be able to change the keyboard settings.
HP Compaq nc6000... | Answered on Jun 20, 2014
You can't restore a compaq nc6000 unless you have the xp disk.In 7 and 8 its much easier to do this, All newer computers have a separate partition with the factory programs in it,This was not an option in xp or older computers.you will have to re-install windows and get all the drivers and software from the HP website.I hope this was helpful
For HP you have to hit F11 when you first start up your computer..
HP Compaq nc6000... | Answered on Jun 10, 2014
Can you please try pressing and holding Shift and then pressing the single quote key ( ' ). Do let us know if that gets the @ sign
HP Compaq nc6000... | Answered on Feb 01, 2014
I would recommend getting a new computer or replacing the motherboard. Solder points get bad and need to be redone.
HP Compaq nc6000... | Answered on Jan 31, 2014
Try connecting an external monitor to the blue D shaped plug on your laptop. If you boot up and the screen appears on the external display., you have a failed backlight or cable on you laptop screen.
HP Compaq nc6000... | Answered on Jan 27, 2014
what if you connect it to external monitor
Try pressing F8 just before it tries to boot and select restore or repair.
HP Compaq nc6000... | Answered on Dec 19, 2013
HP Compaq nc6000 Notebook Logo
587 questions posted
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Toby Lee
Toby Lee
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
hp compaq nc6000 weird thing
  • Computers & Internet
