HP Deskjet F335 All-In-One InkJet Printer Logo
A
Anonymous Posted on Oct 23, 2013
Paper jam in kip 7100 - HP Deskjet F335 All-In-One InkJet Printer
Kip 3000 error 02
he KIP 3000 is a single footprint Multi-Function Printer which can copy, scan and ..... In case the following Error Codes for a serious failure appear in the screen;.
VIP 7100 WITH VOID AREAS
Corona wires need to be replaced, or developer rollers are worn. Wires are the cheapest to replace, but it most likely the developer. You'll need a developer kit and service manual to replace. Your best bet is to contact an authorized service dealer.
Voids when copying
voids or arears of no print could be two things. moisture in paper. try fresh paper out a sealed packet. two- the developer is at fault on needs to be topped up or replaced
I have a clx 3160fn printer and it does not pik up the paper it shows a paper jam in sted can any body help
No I have not yet fixt the problem I have tacken the printer to a repair shop were I hat to pay $50.00 up front they asct me to come at 3 o;clckin the after noon and the talled me there is somesing wrong with softwere and they have order it in from samsung they said the pikup shaft did only half a turn sted a full turn that takes a few days and they will let me know when to pick it up when I have it back I will let you know how things went kip you postet Matt
2helpful
Ricoh CL 7100 fuser jam.
The grinding noise is the clashing of gears. The fuser is composed of 2 rollers, a metal or ceramic with a heater inside (bulb) and a silicon roller to apply pressure. The 'hot' roller is geared and the silicon roller can be geared or free floating. There is at least 1 paper sensor in the the fuser to let the unit know whether paper is there and there when it should or should not be. Sometimes, the sensor gets slightly dislodged and can actually cause a jam. If you are hearing a gear clash, the paper is being pushed through the machine and instead of being pushed through the fuser, it stops because the fuser rollers are not turning. The rest of the machine keeps pushing, crinkling the paper.
If there is crinkling, then gears that drive the fuser need to be checked. It is this gear cluster and/or the fuser that need to be replaced.
Prin ter says out of paper, but paper is loaded
check printer paper sensor it could damaged or dirty and needs servicing. that is the problem
Kip starprint 8000 won't fuse image properly on to paper. Can I manually turn up the temperature on the fuser?
Try some fresh paper directly out of a fresh pack first.Paper begins to absorb moisture as soon as you open the pack.Old damp paper will always fuse poorly.
k24674
Grand Canyon Tech
Grand Canyon Tech
