I don't think my Nuvi 260 could sometimes find a satellite if it were above the car! The unit is on the windshield of a 2007 Camry. It locates satellites perhaps 50% of the time. How can I improve that ratio?
Hi, my name is Vince & i had that very same problem with my nuvi 200w, have you tried to update it on your pc ?, i updated mine after travelling down the motorway at 40 miles an hour thinking that their was road works after the sat nav told me. I also found that updating it seemed to increase the signal strength too, try it, it may solve your problem.
Hello I have a nuvi 1250 and what i did is i put it on my windshield just below my review miror. [and i am telling you this ]it cut the serching in half. and i think that the radio antena might help but i was told that they do that alot so that they are on top of any problems. good luck,
You should place it as far forward on the dash as possible, underneath the front part of the windshield. That gets it out from underneath the metal roof of the car so that it can receive the satellite signal.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
As GPS units are used, data is gathered which
helps them acquire satellites quickly at the start of each use. If a device is
used daily it should be able to acquire satellites in a minute or less. Using a
GPS device while it is outdoors with a clear view of the entire sky is the
ideal condition for acquiring satellites. Please know that there can be several
different factors that may cause a GPS unit to not acquire satellites:
If your unit is trying
to acquire satellites for the first time, it may take longer than normal
to establish an initial position. If the unit is powered on and outdoors
with a clear view of the sky this should not take more than 3-5 minutes.
If your unit has not
been used for an extended period of time (more then a month), it may take
3-5 minutes to acquire satellites.
If your unit is indoors,
it may not acquire satellites. Even standing next to a window indoors will
block a majority of the sky which is needed for a device to locate and lock
onto a satellite signal.
If you have just
finished updating the software in your unit or you have performed a master
reset, your unit may take 3-5 minutes to acquire while outdoors as the
data that is used to locate satellites may have been erased.
If your unit has
traveled over 500 miles while turned off or not tracking your travel, it
may take 3-5 minutes to acquire even in ideal conditions.
If your vehicle has a
protective coating on its windshield or electronic devices which interfere
with the unit receiving signal, your unit may need an external antenna* in
order to acquire satellites.
If you suspect this to
be an issue, try taking the unit outside of the vehicle with a clear view
of the sky for 3-5 minutes so that the unit can acquire satellites. If
your unit loses satellites once moved back into your vehicle you will
most likely need an external antenna*.
If your unit is still having trouble acquiring
satellites, please ensure that it has the latest version of operating software
by using our WebUpdater program. Once
your unit is updated please allow the unit to acquire satellites outdoors in a
stationary position with a clear view of the sky.
*Note: Some units may not be compatible with an external antenna.
Please check the Products tab on the external antenna's page to see if your
unit is listed.
Normal
0
false
false
false
font-size:10.0pt;
If you have just
If your unit has
unit is listed. Good Luck. Did this help?
Normal
0
false
false
false
font-size:10.0pt;
lock onto a satellite signal.
If you have just
If your unit has
try the reset Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
with the unit off, try pressing and holding your finger on the low right corner of the screen and slide the power switch to the on position until you see the message "confirm if you really want to delete
all user data?" hit yes and let it restart. then it will set up the nuvi again, so follow the prompts.
if that fails, hook up the nuvi to the web updater and get the latest update
First make sure you have the latest software in it. If it does try a Master Reset. Lastly, unless you're in a strange location with poor reception. Take it back. Or, it's still under warranty.
Normal
0
false
false
false
font-size:10.0pt;
To perform a Master Reset on your nuvi 260 series device: Note: A masterreset will erase all waypoints or favorites
Start with the unit OFF
and unplugged from power
Touch and hold the lower
right corner of the screen with an index finger or the eraser end of a
pencil
Continue touching and holding
the lower right hand corner of the screen then power the unit ON
Release the power button when
the device powers ON
You will see a new message:
Do you really want to erase all user data?
Remove your finger from the
touchscreen when this message displays
Touch Yes
The device will automatically reset. Follow the on screen prompts then place
your device in an area with a clear view of the sky until it acquires
satellites.
Normal
0
false
false
false
font-size:10.0pt;
If you have just
If your unit has
stationary position with a clear view of the sky. Good Luck
The "New Location" fix above brought my GPS 60 back to full operation. I did reload the GPS software from Garmin but the recovery depended on well charged batteries and as above: turn the unit on press MENU button scroll to "New Location" wait 10 minutes for the GPS to recover.
I experienced the same problem about acquiring satellite signal even when it's a clear sunny day. After 30 mintues, it was still searching!
The unit appeared to have "stuck" in this acquiring mode. The following worked for me:
1) open the GPS antenna
2) press the bottom left screen while holding the power button to turn the unit on
3) enter maintenace mode
4) select diagnostics
5) clear error report, do NOT clear any user data
6) restart unit the usual way
My GPS 350 was able to acquire satellite signal in less than 1 minute after the above steps were taken.
I updated it on my computer, and now it will not locate the satallite. I am in pennsylvania and its looking in kansas.
