20 Most Recent Garmin nuvi 250 GPS Receiver Questions & Answers
HI,
I have the problem solved I at first had this problem after about 5 minutes of messing with my GARMIN NUVI and having many electronic gadget I thought about diffrent buttons to hit at the same time heres how you charge your NUVI with a computer and a usb cable
1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disaper
Garmin nuvi 250... | Answered on Sep 10, 2019
I hope you are trying to be funny, neither am I.
A screen shot is an Image of the SCREEN (the display) of an electronic device. It can be of your Computer Monitor a PDA device's screen or in this instance of the GPS Unit.
You have a "screen shot" of a GPS unit alongside the title of this question.
Is this the question you wanted answered?
Garmin nuvi 250... | Answered on Mar 02, 2018
Use the Garmin Express program from Garmin. Down load and install the program, then connect your GPS to your PC. The program will allow you to install map and software updates.
Garmin nuvi 250... | Answered on Apr 12, 2017
Go to Garmin and download and install Garmin Express, Plug your GPS into your PC. The GPS should power on and Garmin Express should identify it and tell you of any updates. If there is a software update available, that should solve your problem.
Garmin nuvi 250... | Answered on Apr 06, 2017
If you are not the original owner, you will have to hard reset the unit to factory, this will reset all stored information
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 200 and 205 series GPS unit.
I hope that helps.
______________________
Download Nuvi 200 Manuals here.
Download Garmin WebUpdater here.
Backup & Restore Nuvi Favorites here.
Garmin nuvi 250... | Answered on May 27, 2014
Run the battery out completely. Charge it up, them connect it to a PC and perform a system update (or restore) if available
Garmin nuvi 250... | Answered on Nov 13, 2013
The antenna is located inside of the unit. It is about 3/4" square with a silver-plated copper plate mounted to a 1/8" thick ceramic square.
Garmin nuvi 250... | Answered on Aug 30, 2013
You may download the manual and more here.
Garmin nuvi 250... | Answered on Feb 13, 2012
theres two hidden screws under the sticker on the bottom...they are torx screws, remove those then carefully split the case with your finger nail...the battery and the speaker are on the rear half.
Bill
Standing Member of G.O.T.
Please Support Our Troops
Garmin nuvi 250... | Answered on Nov 03, 2011
The time should be automatic unless you are in a different time zone....
Not sure where you are located but here is the way to it to put your time zone
Tools....Settings.....Time.... ( Press ) Time Zone enter your zone there the proper time will appear
Garmin nuvi 250... | Answered on Oct 07, 2011
Please write in English, I do not understand anything. My email: service@gps.pol.pl
Garmin nuvi 250... | Answered on Oct 02, 2011
Going back to the security location will unlock the unit but in order to reset the pin code, the original pin code must be input.
To unlock the unit, it must be sent back to Garmin.
Garmin nuvi 250... | Answered on Sep 20, 2011
Garmin nuvi 250 GPS Receiver Logo
Popular Tags
130 questions posted
Top Garmin GPS Experts
Marvin
Marvin
John Egan
John Egan
Janelle Schoonover
Janelle Schoonover
Are you a Garmin GPS Expert? Answer questions, earn points and help others
View Most Popular
nuvi Garmin
  • nuvi Garmin
Most Popular Question
charge garmin nuvi 250 computer
  • GPS
