20 Most Recent
Garmin nuvi 260W GPS Receiver Questions & Answers
Looking for Map upgrades for Garmin Nuvi GPS
I've looked for free map upgrades for my Garmin and could not find anything. I did find a lifetime map upgrade deal for around $75. It allows you unlimited upgrades for as long as you own the GPS. Go to the garmin site and search NUMaps.
Nuvi 2555mt lost voice
First, do you hear beeps when you press a selection on the screen? If yes, then your speaker is OK and the audio circuits are OK in the unit. Make sure that you have a voice selected in the voice menu. Some units have an audio mixer screen and provide different volume settings for navigation (voice) and system (beeps). maybe the volume for the voice (navigation) is set to off. If you don't hear any beeps when you touch the screen AND you don't hear a voice, make sure that the sound isn't set to be muted. If the sound isn't muted, you may have a defective speaker. More information on audio issues can be found here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
I want to update my garmin 260w with free updates
Garmin provides free updates through their website for the first 60 days after a new unit is put into service. After that, you'll have to purchase map updates. (Software updates are free, though.)
That said, you should first point your browser to www.Garmin.com and go through the process of downloading and installing their browser extension. You might have to reboot your computer or restart your browser to finish the installation.
Return to Garmin.com and register your nuvi. At some point, it will ask you to connect your nuvi to the computer via the USB cable. Do so. Your computer will also go through the process of installing the drivers necessary to view the nuvi as a storage device (so you can download photos and the like).
Once everything is up, the browser extension will tell you what the status is of your nuvi and of its maps. If you're entitled to a free map update, it will allow you to do so. If you're due for a software update, you can do that, also.
Stuck in USB mass storage mode.
Try a master reset:
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
To perform a
Master Reset on the
nuvi 200 series device:
Note: A master reset will erase all waypoints or favorites
and will restore your unit to the default factory settings.
- Start with the unit OFF
and unplugged from power
- Touch and hold the lower
right corner of the screen with an index finger or the eraser end of a
pencil
- Continue touching and holding
the lower right hand corner of the screen then power the unit ON
- Release the power button when
the device powers ON
- You will see a new
message: Do you really want to erase all user data?
- Remove your finger from the
touchscreen when this message displays
- Touch Yes
The device will automatically reset. Follow the on screen prompts then place
your device in an area with a clear view of the sky until it acquires
satellites.
Won't turn off, frozen screen
Normal
0
false
false
false
font-size:10.0pt;
Try "resetting" it.
The reset button on your
nuvi will switch the device off. The reset
button can be used to switch your device off if the screen is frozen and you
are unable to switch the device off by the power button.
To reset a
nuvi 2xx:
- Look at the bottom of the
device
- Locate the small circle with
a dot inside (very small)
- Press the circle to reset the
device.
To reset a
nuvi 3xx or 6xx:
- Lift the antenna
- Locate a button with the word
Reset inside
- Press the button to reset the
device.
The device will now switch off.
Nuvi 260 won't turn on at all.
Had the same problem with my Garmin Nuvi 260w. It just needed to be reset. Lift up the sticker strip on the bottom of the unit and press the reset tab. Worked like a charm for me. HTH!
System software missing
Current version of software is 5.0
Download that as that may be your problem.
You must download the newest version of WebUpdater from Garmin for free to your computer.
Then:
Normal
0
false
false
false
font-size:10.0pt;
To download the latest unit
software visit Garmin website: www.garmin.com/webupdater
After installing WebUpdater once from the Garmin
website, perform all future software updates from your computer. Simply connect
your compatible Garmin device to your computer, then run WebUpdater from your
computer's "Start Menu" by selecting "Start",
"Programs", "Garmin", and finally "WebUpdater"
Normal
0
false
false
false
REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current maps.
Does this help? Let us know. Thanks.
A family member gave my son a garmin nuvi 260 the
Sometimes this problem is caused by the power cord not being pushed fully into the back of the satnav even though it feels like it is. Pushing it in further usually solves the problem. If the power cord you're using is not a garmin this could also cause the problem.
