When i print anything off the internet the black print is fine but anything in color looks like double vision or 3d. the text will be in color but a perfect shadow in light black is up and behind it. i fixed this problem before by phone with a tech but i can't remember exactly. he did a secondary configure is all i recall.
Perform the color calibration through the main menu.. If calibration is successfully done issue resolved, if not check all cartridges are in good condition or not if any one of the defective cartridges will not completes the calibration. If cartridges are OK, then clean the ITB, check the calibration.. Even calibration fails there is mechanical alignment issues raised.
Technical guys only: clean all four laser scanner assembly lenses, check for cartridge driving mechanical alignment..
Resolve the issue on your own, just go through the link shown below and troubleshoot the issue on your own.
https://www.hpsupport365.com/blog/how-to-fix-hp-printer-printing-double-vision
I like the Tech Most likely did a Color Configuration , Go into the Menu and Use the Arrow keys to scroll and look for " Color Calibration " run the test make sure you don't have " Bleeding" this is a term used by Color Tech's like myself to describe that Color are mixing together which is causing your current problem.
Do calibration First.
DOUBLE VISION ON COLOUR PRINTING, PRINTER IS APPROX. 3 YEARS OLD AND WORKED BRILLIANTLY UNTIL NOW. HELP!
change toner cartridge or repalce cleaning blade drum (https://mucinhanoi365.com/)
