20 Most Recent
Da-Lite Tensioned Director Electrol 89986 Projector Screen Questions & Answers
How do you calibrate a rearprojection panasonic
OK, I know this set very well--if convergence in the customer menu is skewed and red or blue will not adjust in some direction, you have a convergence problem.
I can give you (post here) START TO FINISH STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS MODEL.
It requires that you are able to solder etc---not real hard even if you have never done it before.
Considering you can buy the parts on Ebay for about 20 dollars if you can do it yourself or know someone who can do it for you--you can save the set and a lot of money......most shops get 300 or more for this kind of trouble.
If you want the instructions let me know and I will post them.
I can tell you the best place to get the chips--this set uses two STK-392-110 CHIPS.
Usually just both chips need to be replaced and the set adjusted.
The instructions tell you everything you will need and how to do the fix.
I composed them from my own experience and because many people here ask the same thing you did.
If you have questions etc, let me know. I am here to help people.
If this has helped you, rate this solution as I do this here for free.
Thank you for using Fixya.
SD TECH
11/21/2009 3:51:29 AM •
Da-Lite...
Answered
on Nov 21, 2009
How do i repair fabric on projection screen
happy to help but sorry u cant repair the fabric if its torn . but i could give a u tip . try using medical tape that is used on injuries. its white and can stick in any weather. and its a cheap fix .
How long should I leave the charging cart on?
You only need to charge the battery to 100% then you can disconnect the power adapter.To
monitor the charge state of the battery click on Start - Control panel -
Power Options - Power Meter tab then you can see the charge state of
the battery.
